Vortex Cones - Road Glide Forums
  • 1 Post By Thermodyne
post #1 of 6 (permalink) Old 12-20-2018, 12:25 PM Thread Starter
Still Grumpy's Avatar
Vortex Cones
Does anyone have any experience having used these cones?
I'm looking for a quieter exhaust now that true Duals were installed using my CFR slip-ons.
The exhaust note has totally changed from what I believe is the best sounding exhaust out there
(CFR slip ons with the stock head pipe)
Anyways, I called CFR directly and they said my only option to quiet the exhaust was to install these Cones ( $99 each from Jegs Performance)
Anyone try them? Are they worth the $200 ?
Im am currently trying to sell the CFR's but at least now I have this option if I decide to keep them
thanks !
Still Grumpy is offline
post #2 of 6 (permalink) Old 12-20-2018, 12:44 PM
Thermodyne's Avatar
If you have a 4 inch opening that you can slip a baffle into, look into the Rex spiral header baffles.
Thermodyne is online now
post #3 of 6 (permalink) Old 12-20-2018, 01:21 PM Thread Starter
Thank you Thermal.
It looks like these are attached with one bolt drilled thru the muffler's end?
post #4 of 6 (permalink) Old 12-20-2018, 01:38 PM
Thermodyne's Avatar
Originally Posted by Still Grumpy View Post
Thank you Thermal.
Yep, one bolt through the side. I used them back when I was jet boating. They were much less restrictive than the other stuff that was around back then.
post #5 of 6 (permalink) Old 12-20-2018, 04:00 PM
Little Wing's Avatar
Yep, on bolt through the side. I used them back when I was jet boating. They were much less restrictive than the other stuff that was around back then.
wow. i've never seen those.
looks like they would definitely cancel any reversion problems
how do the effect scavenging?
Little Wing is offline
post #6 of 6 (permalink) Old 12-20-2018, 04:27 PM
Thermodyne's Avatar
No idea. When I built those boat motors I used mule headers for the dyno work. And, paying by the hour, I didn't spend a lot of time on the baffles. It was all about getting the oddball carb to work. On the mule headers, they cost a few horses on top, but added some in the low to mid range. But they were considerably better than the the other units. They all restricted the opening down to less than 3 inches.
I ended up just cutting one in half, and putting a piece in each header. I doubt it would have past a sound test, but all the DNR cops ever did was look in the ends with a flash light. If they saw a baffle, they let you go.
Little Wing likes this.
Vortex silencer. gman Intake and Exhaust 0 09-19-2018 05:11 PM
Vortex Viper PST 4-16 Riflescope Sealdoggy Miscellaneous for Sale 0 11-12-2014 05:23 PM
Any thoughts on Bell Vortex macked Helmets 0 04-10-2013 09:44 PM
Power Cones or Torque Cones Howardsternspenis Intake and Exhaust 1 03-10-2012 02:36 PM
