Removing the Cat Question - Road Glide Forums
 2Likes
  • 1 Post By FLTRXS20
  • 1 Post By RGKen
post #1 of 8 (permalink) Old 03-13-2019, 03:42 PM Thread Starter
2018 Road Glide Special with Harley tuner. Does removing the cat really help with the heat to make it worth removing the cat or replacing the header without the cat? Also, from what I have read, a tune is not needed if the cat it removed? Since I already have the HD tune, I would not think a followup would not be needed?
Thanks for any input
gtmedic likes this.
FLTRXS20 is offline
post #2 of 8 (permalink) Old 03-13-2019, 04:18 PM
RGKen's Avatar
Yes removing the CAT will reduce the heat and no you will not have to retune.
gtmedic likes this.
2018 FLTRXS
RGKen is offline
post #3 of 8 (permalink) Old 03-13-2019, 07:41 PM
This is good news. I had the same question.
Would you say it is a significant reduction in heat on your leg?
Jeremy (Gulf Tango)
2017 FLTRU
gtmedic is offline
post #4 of 8 (permalink) Old 03-13-2019, 07:59 PM
RGKen's Avatar
Yes.
2018 FLTRXS
RGKen is offline
post #5 of 8 (permalink) Old 03-13-2019, 08:22 PM
mastergunnera8's Avatar
Ok, I'm confused (not hard to do)...go catless and no need to re-tune? M8 magic?
There are possible warranty implications too, right?
mastergunnera8 is offline
post #6 of 8 (permalink) Old 03-13-2019, 10:30 PM
rideon's Avatar
What’s the sound like, Cat removed with stock mufflers?
2018 Road Glide Special, vivid black
rideon is offline
post #7 of 8 (permalink) Old 03-14-2019, 06:49 AM
RGKen's Avatar
Re-tuning would be optimal anytime you make a change to the exhaust but making very small changes like just changing the A/C or just changing the slip-ons are not enough to make a big difference in the tune. So just removing the CATS would not make a big enough difference to the flow out. I used to think that the CATS created a lot of back pressure but have since found out that they really don't. At least not enough to make a difference in the tune but you are correct in that you could run into warranty issues depending on what the issue is and if it can be connected to the exhaust. Even then I have heard that the EPA has fined the MoCo for every bike that they have been caught doing warranty work on that has had modifications done that take it outside of the EPA standards. Some dealers may still try and give you a hard time about it.
2018 FLTRXS
RGKen is offline
post #8 of 8 (permalink) Old 03-14-2019, 09:34 AM Thread Starter
All, thanks for the replies.
FLTRXS20 is offline
Tuner question from noob surfrat2 ECM/Fuel Management systems 7 01-27-2015 11:35 AM
Question on Removing Speedo/Tach Bezel FLTRXS20 *General Road Glide Discussions/Pictures 4 12-01-2014 07:35 PM
removing exhaust baffle question Bigfoots03hd Intake and Exhaust 7 09-12-2013 11:17 PM
Extended Warranty Question 100edition New Members Welcome Area 13 03-12-2013 12:53 PM
Question on removing front wheel Dmize Wheels and Tires 26 01-14-2013 02:00 PM
