Need to Decat but warranty worries - Road Glide Forums
 2Likes
post #1 of 17 (permalink) Old 05-24-2019, 06:14 PM Thread Starter
I just purchased a 2019 Road Glide Special with the 114 motor. I'v put about 2000 miles on it so far and only problem was the oil transfer from transmission to primary. The dealer has installed the vent kit under warranty. The only change I have done to the drivetrain is a set of Rhinhart slip ons. The weather has been very warm for this time of year but the heat coming of the bike is unbearable. I think the answer would be to decat the headers but then I would need to install a tuner and that will void the warranty. Don't know if I can wait the two years until out of warranty?
panman65 is offline
post #2 of 17 (permalink) Old 05-24-2019, 06:55 PM
If you do decide to decat the header, you can purchase a oem decatted header from the auction site pretty reasonable price. This way you can keep your header for just in case. Others may know more than I, but the ox sensors are before the cat and if your state does not have epa test for motorcycles, no issues there. Also, a Harley tech would have to have a reason to look under the bike to see a different weld on the exhaust pipe. Not sure if when a tech access the ecm, it has the ability to detect exhaust flow, etc. Yes, a tune would be good to do and a Harley tune keeps your warranty, but not the best tune out there.
I did all the above, HD tune, stage 1 and street cannons, it worked for me and I have not had any issues with the Harley dealer.
Like I mentioned, other will know more than I.
FLTRXS18 is online now
post #3 of 17 (permalink) Old 05-24-2019, 08:51 PM
craigffb's Avatar
Mine doesn't feel any hotter then my 103 did with V&H Power Duals on it.
craigffb is offline
post #4 of 17 (permalink) Old 05-26-2019, 10:58 PM
georgec's Avatar
Pickup an OEM header and decat yourself. You don't have to cut and weld. I drilled one out, just took a couple of hours. That way you still have your stock header.
Then, get the SEPST.
georgec is offline
post #5 of 17 (permalink) Old 05-27-2019, 01:41 PM
You can always buy the engine fan. I hear they work well pulling the heat off the riders.
Big_gary is online now
post #6 of 17 (permalink) Old 05-28-2019, 01:22 PM
Bansh's Avatar
I'm Having the same problem, wife complaining about the heat coming up from exhaust. Is there another guard that can keep the heat away from the passenger, or am I better off changing the exhaust? I have the blacked out motor and like the looks.
2019 RGS 114 motor
2019 Road Glide Special 114 Hot Rod Red, and blacked out!
Bansh is offline
post #7 of 17 (permalink) Old 05-28-2019, 08:55 PM
18 Wicked Special's Avatar
I have the same complaint on my 2018 RGS. Warranty is my concern too, extra 2 yrs worth. While moving, place your right hand below the seat, the heat seems to be coming from the rear cylinder area out the right side, above the cat(negligible on the left side). Not sure how much decatting will improve this. With the cylinders growing in diameter with larger displacement engines, there's less open space. Looks like the coolflow fan accessory may be the most effective means to shed the heat away from rider/passenger.
I plan on installing the warranty friendly SE pro street tuner for performance gains and possibly slightly less heat from a richer mixture. The coolflow fan may be the my next upgrade after that. Along with diverting heat away from rider/passenger, it has to be pulling extra heat off the rear jug. Down side is it shuts off above 40mph.
My.02
18 Wicked Special is offline
post #8 of 17 (permalink) Old 05-29-2019, 08:06 AM
wevsspot's Avatar
Whatever choice you make, keep in mind the warranty implications. If you're going to tune, don't let the dealer do anything other than the HD approved Street Tuner (EPA compliant). If you gut the CAT, keep one completely stock head pipe in reserve in case you ever have a major power train warranty issue. Also, don't use any other AC except the Harley "Stage 1" AC variations. Basically, all HD EPA approved "performance" parts. The Rinehart mufflers shouldn't throw any flags, so you should be good there.
wevsspot is offline
post #9 of 17 (permalink) Old 05-29-2019, 09:48 AM
RGKen's Avatar
You don't need to use a SE A/C. Any quality brand A/C will work and will not throw any flags against your warranty.
2018 FLTRXS
RGKen is offline
post #10 of 17 (permalink) Old 05-29-2019, 01:02 PM
wevsspot's Avatar
Wasn't speaking specifically of DT flags, speaking of the kind that the dealer might throw or what grenades the mother ship might throw if they start asking for descriptions, documentation, pictures etc.
He's already dropped the coin on the mufflers, so I figured they would be staying one way or another. In reality the stock M8 AC flows more than enough intake volume as is, but my dealer won't do a "Stage 1" tune without the slip ons and "upgraded" intake. Not sure it's worth risking an after market AC when there are a couple of approved options available.
That was my point.
wevsspot is offline
Warranty issues with Harley is REAL! gkt33 *General Road Glide Discussions/Pictures 52 05-30-2019 12:34 PM
Intake / Exhaust could void warranty ??? also set up thoughts BadKarma1701 Intake and Exhaust 8 11-26-2016 09:46 AM
Warranty almost up - getting nervous... Methos1979 *General Road Glide Discussions/Pictures 35 09-01-2014 10:38 AM
Failed rings...extended warranty may not cover? pastryslayer Engine Related 21 05-26-2014 09:29 PM
Extended warranty question... Johnzz1420 *General Road Glide Discussions/Pictures 4 07-12-2012 09:39 AM
