V&H header cracked - Page 2 - Road Glide Forums
post #11 of 17 (permalink) Old 09-02-2019, 09:16 PM
craigffb's Avatar
Originally Posted by Big_gary View Post
Seen it happen in the past when the pipe is hard mounted to the frame on rubber mounted engines.
You mean like how the OE one is?
craigffb is offline
post #12 of 17 (permalink) Old 09-02-2019, 09:25 PM
Really ? No rubber grmoment in there ?
post #13 of 17 (permalink) Old 09-02-2019, 09:42 PM
craigffb's Avatar
Nope, just two bolts and the bracket. The V&H pipe mounts to the same point, just uses a different bracket. That way on all Harleys.
craigffb is offline
post #14 of 17 (permalink) Old 09-02-2019, 09:46 PM
I guess the motor co, just figured harley guys will just buy the SE version when they crack. Something has to give in a 2 part system when connected hard mounted.
post #15 of 17 (permalink) Old 09-03-2019, 05:40 AM
Bandit 7's Avatar
Same thing happened to mine on my 2012, broke in the same spot as yours. Mine had around 90,000 mile on it when it broke, V&H did not replace it because they had been on the bike for 7 years.
Bandit 7 is offline
post #16 of 17 (permalink) Old 09-08-2019, 08:51 PM
Stick_FSMC's Avatar
I've had both pipes crack on the 2012 RGU.
I never contacted V&H.
I scrape my pipes in the corners and I've bottomed out both sides at the back of the mufflers.
I just welded them back up. I currently have 95K on the bike and the pipes went on when I bought it.
Right side failed in 2015, left side was earlier this year.
Both took a weld and are still running well on the bike.
Stick
USAF 1980-84
Stick_FSMC is offline
post #17 of 17 (permalink) Old 10-01-2019, 06:08 AM
So did Vance and Hines send you a free replacement?
2015 Road Glide Special Vivid Black
edimean22 is offline
