V&H header cracked - Road Glide Forums
post #1 of 17 (permalink) Old 08-30-2019, 11:44 PM Thread Starter
NewYorkRhino's Avatar
V&H header cracked
Just happened this week. Bike is a 2016 that I bought new, added the V&H power duals head pipe with hi outputs shortly after buying.
Riding down the highway and I started to hear a rattling noise and the sound of an exhaust leak. Got it home and left it until a few days later when I had time to start poking around to see what was going on. Pulled off a couple of the heat shields and see that the pipe coming off the rear cylinder has cracked and completely separated from the ‘X’ portion of the header.
Sent V&H a message to see what my options are. I’ll update if a resolution is found but wanted to show the pics and see if anyone else has had this happen with their V&H header pipe? If so, what was outcome?
File Type: jpeg D9275F03-9C36-49DA-AA99-96896344F7F1_1567222810360.jpeg (225.1 KB, 75 views)
File Type: jpeg 3ABDB49B-5EA9-4414-B0B2-B699F6EBFA35_1567222824868.jpeg (100.8 KB, 67 views)
File Type: jpeg C0CB8A12-3AA9-4097-8881-3D3A75B91312_1567222837115.jpeg (198.4 KB, 66 views)
NewYorkRhino is offline
post #2 of 17 (permalink) Old 08-31-2019, 12:18 AM
craigffb's Avatar
I cant tell from the pictures, but you didn't bottom out the pipe did you? V&H has always done me right every time I've had an issue, even when I didn't think they would.
craigffb is offline
post #3 of 17 (permalink) Old 08-31-2019, 12:34 AM
Desert Rider AZ's Avatar
Owned my share of V&Hs and they usually stand behind their products. Never had that happen to my own pipes but back in the 90s on a rental Electra Glide,the stock header pipe cracked on me while riding from Tombstone back to Phoenix
Desert Rider AZ is online now
post #4 of 17 (permalink) Old 08-31-2019, 07:28 AM Thread Starter
No bottom out and pipe has never scraped in a turn. I saw some people have had that happen.
post #5 of 17 (permalink) Old 08-31-2019, 09:31 AM
UltraWalt's Avatar
I had that happen on my 12 a few years ago and V&H made good on it. Sent me a new head pipe after a few days of contacting them.
2019 Roadglide Ultra
UltraWalt is offline
post #6 of 17 (permalink) Old 08-31-2019, 10:46 AM
craigffb's Avatar
@NewYorkRhino
As long as the pipe wasn't hit this ^ is more then likely gonna be the out come. They sent me a replacement for an air filter the cracked at the bolt hole and I had the filter for about 9 years. V&H is a stand up company.
craigffb is offline
post #7 of 17 (permalink) Old 08-31-2019, 03:59 PM Thread Starter
@NewYorkRhino
Good to hear all the positive outcomes. Hoping mine goes the same way, love the deep rumble of this set up.
post #8 of 17 (permalink) Old 09-01-2019, 04:33 PM
Dam that sucks. Ive read before about VH pipes cracking. Possible to take a picture of the inside of the crack? Lots of undercut on the left side of the weld = too hot. A weld like that should never pass inspection
phillyfan1 is offline
post #9 of 17 (permalink) Old 09-01-2019, 05:53 PM
Silvereagle50's Avatar
Had a set on my 2012 SG. The crack was in the “x” of the pipe somewhere.
I had bought them and had them installed at a dealer.
They contacted V&H and sent out a new set pretty quick.
Mike Hutchings - SE Okla.
2016 CVO RGU
Silvereagle50 is offline
post #10 of 17 (permalink) Old 09-02-2019, 07:41 PM
Is it mounted properly? Seen it happen in the past when the pipe is hard mounted to the frame on rubber mounted engines.
