So little and such a PIA! - Road Glide Forums
post #1 of 21 (permalink) Old 12-13-2013, 07:59 PM Thread Starter
RoadGlideGary's Avatar
Okay how is it something so little can be such a PIA to change out? Decided today to remove the straight grease fitting on the steering head to a 90 degree for easier access. Got the old one off without any problem. Spent way to long trying to install the new. Holly shit Bat Man! Do you think the access could be any smaller to do this?! Finally gave up and decided to wait for another day. I only hope I find a less difficult way to do this - otherwise bases on my first attempt it could be a long time. Anyone else done this? Advice appreciated!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #2 of 21 (permalink) Old 12-13-2013, 08:04 PM
JacktheBagger's Avatar
It is a snug fit , mine has a sheath of wires dead center of the grease fitting , I just put a longer hose on the grease gun , and I have to run it from underneath ..
Tour Glides had much more room there
JtB
2011 Ultra
JacktheBagger is online now
post #3 of 21 (permalink) Old 12-13-2013, 08:07 PM Thread Starter
JtB
Got the length on my hose! It getting the new fitting on the steering head that is giving me fits!
post #4 of 21 (permalink) Old 12-13-2013, 08:36 PM
Banned
Why not just put a 90 degree fitting on the grease gun and not jack with the fitting on the neck?
Sent from Motorcycle.com App
Scootin is offline
post #5 of 21 (permalink) Old 12-14-2013, 09:32 AM Thread Starter
I should have done that do doubt. I will give it another try today and if this attempt does not work I put the original fitting back on and take your advice.
Ride safe and thanks for the option.
post #6 of 21 (permalink) Old 12-14-2013, 11:26 AM
I changed mine back in 08 and it was a PIA. It has been a while but I think I installed a 45 degree zerk fitting and I aimed it forward towards the front of the bike. That way I just grease the steering neck when I have the outer fairing off and the fitting is real easy to get to, I just have to push aside some wires. You only have to grease the steering head bearing every 10,000 miles according to the service manual and with the outer fairing being so easy to remove/install it just made sense to do it this way, besides I have the outer fairing off at least 10 times or more a year.
post #7 of 21 (permalink) Old 12-14-2013, 02:11 PM
smitty901's Avatar
Fun, like most things once you do it figure out your way it is not so bad.
smitty901 is offline
post #8 of 21 (permalink) Old 12-14-2013, 03:02 PM
but it's always after you bust a knukkle or bump your head or spill your beer
reds4 is offline
post #9 of 21 (permalink) Old 12-14-2013, 04:05 PM
smitty901's Avatar
On my third RG or RGU. Try this cover the tank well.
Turn bars all the way to the right. put tip in your left hand one finger extended. reach in and run finger between wire harness until you feel the zerk stick it on and pump. Much easier than trying from below.
Make sure it is the zerk the is a bolt stud in that area.
post #10 of 21 (permalink) Old 12-14-2013, 04:11 PM
reficul's Avatar
You guys are really pumping that much grease into your stearing head?
2012 Shark Face
One day he is gonna answer
reficul is offline
Miscellaneous ramblings and such killintime *General Road Glide Discussions/Pictures 6 08-17-2015 08:06 PM
I'm such a wannabe!!! RGB11 New Members Welcome Area 32 06-04-2012 11:41 AM
Is there such thing as to much paint? piesik650 Paint & Bodywork Section 40 04-06-2012 04:16 PM
Tuners and such - basic questions 1st Sgt ECM/Fuel Management systems 3 02-14-2012 01:37 PM
pitchers and such JacktheBagger *General Road Glide Discussions/Pictures 11 12-04-2011 09:31 AM
