Milky oil? - Road Glide Forums
post #1 of 15 (permalink) Old 01-04-2014, 08:24 PM Thread Starter
Stag556's Avatar
Milky oil?
I've had my bike up on my lift for about a week now. I drained the oil in anticipation of changing out my chrome engine cases to wrinkle black. The oil looked fine when I drained it. (I'm very anal and change my engine oil every 2500 miles. May be overkill but it makes me happy).
When I removed my rocker cover, there was normal golden oil and then some areas where it almost appeared milky. Nothing extreme but over the years I've always taken little signs as a precursor to larger problems.
It had been very cold out, hitting -4 last night, could low temperature cause that? I've never seen that before.
I use Mobil 1 20w50.
Oh, it's a '13 RGC with 7k on the trip.
Stag556 is offline
post #2 of 15 (permalink) Old 01-04-2014, 08:37 PM
cnidog's Avatar
Well, I don't have an answer, because the easy answer for milky oil is water in the oil.
"where the incompetent lead the inexperienced, to do the unnecessary, just in case" - me
IBA Member # 55664
cnidog is offline
post #3 of 15 (permalink) Old 01-04-2014, 08:55 PM
perrykw's Avatar
Only answer I have is water.
perrykw is offline
post #4 of 15 (permalink) Old 01-04-2014, 09:02 PM
bpt-bagger's Avatar
It could be condensation. Do you wash it with water heavily? Store it in a humid place? Etc
bpt-bagger is offline
post #5 of 15 (permalink) Old 01-04-2014, 09:13 PM
I would have to agree with some type of moisture, condensation of some kind. Couldnt answer how though
post #6 of 15 (permalink) Old 01-04-2014, 09:14 PM
mocotom's Avatar
If your short hoping the bike a lot in cool or cold weather, the oil will often get a high concentration of moisture in it causing the milky appearance. The motor needs to run long enough for the oil to reach normal operating temp on a regular basis to prevent the excess moisture.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #7 of 15 (permalink) Old 01-04-2014, 09:37 PM Thread Starter
Stag556's Avatar
Thanks for all the replies.
It is stored in my garage in NJ, not heated but indoors. The bike has sat for a while because of colder temperatures and poor road conditions due to salt.
I usually come out and start her and let her warm up so she doesn't sit idle all winter. Then after she's warm, I kill it.
Like I previously stated, the oil that came out of the pan was still golden and had no signs of "milky". You guys could have hit the nail on the head with condensation.
Stag556 is offline
post #8 of 15 (permalink) Old 01-04-2014, 09:54 PM
faststan's Avatar
Definately condensation. I saw that a lot in my motors I left to sit for extended periods of time when I lived in a cold climate. Just starting the bike/car will not get rid of it very quickly. It needs to be brought up to operating temp for a period to get the condensation to mix with the oil and be drawn thru the filter. JMO
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #9 of 15 (permalink) Old 01-04-2014, 11:54 PM
Psycho's Avatar
[QUOTE=Stag556;1422610]Thanks for all the replies.
^^^^ One of the worst things you can do. Fresh oil, full tank of fuel with fuel stabalizer, battery tender and store for the winter, your practice creates condensation that is not good. Please stop this practice.
2009 Road Glide/Red Hot - Denim
Psycho is offline
post #10 of 15 (permalink) Old 01-05-2014, 12:33 AM
I also agree with condensation. It's not good to just start your bike & let it run, which cause condensation. Battery tender, some type of fuel stabilizer for sure. Good luck.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
Brake Fluid is a Milky White Color RGKen Troubleshooting for Road Glides 9 05-11-2016 05:39 AM
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 09:44 AM
What to do with oil change oil? TearlessTom *General Road Glide Discussions/Pictures 15 11-22-2011 08:16 PM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 11:38 AM
Lower your oil temp by changing your oil...??? dklanecky Do-IT-Yourself 14 07-07-2010 09:29 PM
