I'm an idiot! - Road Glide Forums
post #1 of 14 (permalink) Old 03-01-2014, 09:49 AM Thread Starter
Brianu1's Avatar
I'm an idiot!
Didn't realize you are supposed to change the oils in the fall when you put the bike away for the winter vs. change in the spring before the riding season starts. Hopefully it's not an issue. I've never done it that way with any of my bikes, and I've never had any issues, but the HD dealer scolded me yesterday! Now I know!
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 14 (permalink) Old 03-01-2014, 09:56 AM
You should be good I wouldn't sweat it.
post #3 of 14 (permalink) Old 03-01-2014, 09:58 AM
That"s nothing worthy of a scolding.
roadglidetouring is offline
post #4 of 14 (permalink) Old 03-01-2014, 10:07 AM
It's not like you stored the bike for a few years. ..... even though with the way this winter is going it may be... you'll be ok.
Sent from my SPH-L710
post #5 of 14 (permalink) Old 03-01-2014, 10:21 AM
I'd rather change in the spring..otherwise,the oil sitting in the bike all winter would age,like oil sitting on a shelf.
Dealer scolded you cause that's less money he got in the fall
danglide is offline
post #6 of 14 (permalink) Old 03-01-2014, 10:39 AM
OldNerdGuy's Avatar
As a general rule, never believe anything you hear from a dealer until you realize that everything they say is meant to separate you from some of your money. Period.
I said as a general rule. There are always exceptions, and when you find them, cherish them.
Here is a fer instance...
When I was looking for my Road Glide, I found two locally. Both the same color, one a 2008, one a 2009. I tested the 2009 to death. The sales guy was very accomodating. The day before I decided to pull the string, I found one hell of a deal on Craigslist. Problem was, it was in Milwaukee and I live outside of St. Louis. I took the Craigslist ad to the dealer, and said that "in all fairness, I have to show you this". It was also a 2009, at $1700 less than their asking price, and included a Tour Pak. Note: I had already bought one bike from this guy, so we knew each other.
Sales guy took the ad back to the closer dude (the one who does all the paperwork). Both came out and said this... "Dude, you gotta go get this, there is no way we can touch this deal, we just have too much
into our bike". They have been my favorite dealership ever since.
OBTW, this is what I ended up with, from Craigslist, 3 years and 60,000 miles ago....
As for the oil, don't sweat it, just make sure you get fresh in before you ride. Depending on the mileage, you might want to consider all three holes (crankcase, primary, transmission).
OldNerdGuy is offline
post #7 of 14 (permalink) Old 03-01-2014, 10:52 AM
dirtyb's Avatar
I've never heard of oil "ageing" sitting on a shelf . Not saying it does or doesn't but never heard that before and have to question where you got that info from?
No matter when you change your oil someone will tell you that you changed it at the wrong time. I personally change mine in the fall because I don't want dirty oil sitting in my motor all winter. My cousin changes his in the spring because he doesn't want oil with condensation in it when he starts riding in the spring(I have a heated garage so no worries their for me). Do what works for you and call it good.
2012 Road Glide CVO
2008 nightster (wifes ride)
2007 Street Glide Sold
2002 Heritage Sold
dirtyb is offline
post #8 of 14 (permalink) Old 03-01-2014, 11:41 AM
It is best to change the oil before storage because of the acids that are in the oil. The acids are a result of the engine running and exhaust gasses getting into the oil.
The biggest reason for condensation in the engine oil as a result of storage comes from running the engine in cold weather, the heating and cooling will result in condensation build up.
The best thing to do when storing the bike is to leave it alone and don't start it until you take your first spring ride. JMO
post #9 of 14 (permalink) Old 03-01-2014, 12:15 PM
Bigtrev8xl's Avatar
And in reality, it makes no dam difference at all, when you change the oil
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #10 of 14 (permalink) Old 03-01-2014, 12:17 PM
sj01fltri's Avatar
I too change my oil in spring,ride the bike for about 20-30 miles come home and change it,it is like the others have said do what works for you.My last RG had 60,000 miles on it when i upgraded to a SE cam plate and oil pump,cam chest was spotless,my 93 FXR has 72,000 on it with out any major issues,other than base gaskets leaking at 55,000 miles,that motor was also clean when i pulled the top end off.
sj01fltri is offline
God sent an idiot to warn me about my wicked ways. outcast1 *General Road Glide Discussions/Pictures 29 09-16-2013 09:55 PM
I'm an idiot so learn from me !!!! 13HDGLIDE Tech Area 52 07-13-2013 06:38 AM
Dropped my 2010 FLTRX last Friday...I'm an idiot Chaz *General Road Glide Discussions/Pictures 27 08-18-2012 04:49 PM
Idiot ruined my windshield faststan Windshields 17 03-09-2012 10:03 AM
I'm an Idiot! hodgeaaco *General Road Glide Discussions/Pictures 14 09-20-2011 07:04 PM
