First Full Fluid Service since Purchase - Road Glide Forums
post #1 of 19 (permalink) Old 03-15-2014, 03:58 PM Thread Starter
BILBO's Avatar
I bought an '03 RG (In Oct. of last year) from a friend of mines Uncle. He purchased it new, and while under warranty, all service was done by Harley.
After the warranty he did the service himself.
His entire family are "car/bike/boat/ATV" people. I trust them ENTIRELY...
AFTER the purchase we have talked and he said he continued to use the Harley SYN 3 for all services.
The bike had JUST UNDER 27k when I took ownership.. And it had JUST HAD ALL FLUIDS CHANGED (before the new owner took possession)
I have put 5k miles on it and wanted to do a fluid change.
I bought all the fluids and parts from the dealer and upon starting the job, I noticed the amount of fluid that I drained from the primary case is MORE THAN 32 ounces as the service manual calls for...
My question is this... Should I Follow the manual, or put the amount back in, that came out?
I do all services (that I have knowledge of, and tools to do) myself.
I've never done a service on a bike so this is "new to me"
I have a truck with over 300k miles on it that I've serviced since I took ownership with 28k miles on it..
I'm not scared to do it... Or learn it...
I just like to "dot all my I's and cross all of my T's "
Also... The part/gasket I got for the clutch inspection cover LOOKS NOTHING, like what came off..
BILBO is offline
post #2 of 19 (permalink) Old 03-15-2014, 04:06 PM
The bike should be upright not on the kickstand when doing the primary fluid change. Just add what is in the service manual not what you drain out. Just as long as the primary fluid reaches the bottom of the clutch basket you will be alright. If you don't have a service manual it would be a good investment.
post #3 of 19 (permalink) Old 03-15-2014, 04:17 PM Thread Starter
BILBO's Avatar
I do have the 2003 service manual..
I purchased it the same time as the fluids/filter/plugs/gasket...and it says... 32oz...
BILBO is offline
post #4 of 19 (permalink) Old 03-15-2014, 04:20 PM
sj01fltri's Avatar
As far as the gasket they change the gasket a few yrs ago,so when you go to the dealer for a replacement you will get the upgraded one.
sj01fltri is offline
post #5 of 19 (permalink) Old 03-15-2014, 04:22 PM Thread Starter
BILBO's Avatar
32oz.. Brings the fluid nowhere close, to the bottom of the clutch basket...
BILBO is offline
post #6 of 19 (permalink) Old 03-15-2014, 04:29 PM
Jay2Beers's Avatar
I've been told many times by many indies - 38 oz. I have even had HD mechanics tell me 38oz.. I put 38oz. in my Primary.
I had an 09 Roadking with the 96 - when I changed the primary fluid for the first time (post dealer and indies changes) it had 47oz. My seal between the crankcase and the primary was craked and leaking into my primary. Oh and Yes, on that RK I had added oil several times when it was getting low, between the oil changed,... That should have been my first clue.
'13 Blk RGC crs/abs/sec 103 Stg2 255cam-plus D&D Boss Fatcat SE Super Tuner. Klockwerks 12", Blk 10"Chubby w/Blk Get-A-Grips. Skunked Day Maker. CD GEN2001157Amber/Wht Front & Red Rear Smoke Lens w/Magic Strobe & bits more, Always a WIP
Jay2Beers is offline
post #7 of 19 (permalink) Old 03-15-2014, 04:50 PM Thread Starter
BILBO's Avatar
It looks NOTHING AT ALL like what is on there now...
What they gave me.. Looks like a flattened out/inverted o-ring... Part # 17369-06
What's on there now...
Is a saucer shaped solid gasket
Part #25416-99C
BILBO is offline
post #8 of 19 (permalink) Old 03-15-2014, 04:51 PM Thread Starter
BILBO's Avatar
Thanks for alkyl of the help and suggestions... Greatly appreciated....
That's why I Join
And Love Forums!
BILBO is offline
post #9 of 19 (permalink) Old 03-15-2014, 05:06 PM
Use the one that came off the primary, on the sidestand put the 32 in, cut the funnel end on a 60 degree rest it on the the pressure plate pour slow, make the drain is in near flush, tighten back up as you would lugs on your truck just not so tight
this is the way been doing the fluids on my 03 for over 80K, ask away, that is the correct amount stock, neatly, wrap teflon tape neatly @ the plug
get the right oil filter wrench, it has a open gap so you don't rip the sending unit out, or use channelocks to remove, every ting is the same as you work on others, do the tranny if fluid is dirty or scum from wtr, follow the manual, I only do it about every 20k or more on glide or king
reds4 is offline
post #10 of 19 (permalink) Old 03-15-2014, 05:24 PM
And yes, been using the same gasket since likely 05 been alternating 3k oil and 6k pri since 03, tensioners went out @ 85k
reds4 is offline
First fluid change in the Batwing! Dmize Fluids and Lubricants 10 06-26-2015 08:35 PM
Took my first ride since Heart Surgery ironmark General Off-Topic Discussions 16 06-13-2014 07:31 PM
First ride since winter mods neuropac General Off-Topic Discussions 6 04-07-2013 11:08 AM
