Transmission and Primary Oils... - Road Glide Forums
post #1 of 19 (permalink) Old 03-29-2014, 09:12 PM Thread Starter
The Volusianator's Avatar
Why don't they need filters?
The Volusianator is online now
post #2 of 19 (permalink) Old 03-29-2014, 09:44 PM
JacktheBagger's Avatar
They are closed systems compared to the motor , the oils stay in the primary and trans compartments .. There is no contamination to filter like in the motor
JtB
2011 Ultra
JacktheBagger is online now
post #3 of 19 (permalink) Old 03-29-2014, 09:50 PM
tmd
Same reason a manual trans on a car doesn't have a filter. Closed system with no outside contaminates.
tmd is offline
post #4 of 19 (permalink) Old 03-29-2014, 10:04 PM Thread Starter
Fair enough, thanks fellas.
post #5 of 19 (permalink) Old 03-30-2014, 03:34 AM Thread Starter
OK, so just thinking about this a little more, what are the "outside contaminates" that are in the motor that need to be filtered?
post #6 of 19 (permalink) Old 03-30-2014, 08:35 AM
all the crap created by internal combustion doing combustion things , the oil is constantly picking up and moving minute particles of engine metals , and some of that stuff isn't caught by the filter , I have Used Oil Analysis done every oil change and it shows how much metals are still in the oil , the filter doesn't catch
JtB
2011 Ultra
post #7 of 19 (permalink) Old 03-30-2014, 09:59 AM
chromedome's Avatar
soot from semi-burned fuel & oil, unburned fuel, Un-filtered particles of "dirty air", metal filings. those are the ones I can think of.
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #8 of 19 (permalink) Old 03-30-2014, 10:47 AM
mocotom's Avatar
Agree with the above posts, but you also need to consider that neither the trans or primary utilize a pressurized oil system that is normally associated with filtering. Small fuel burning engines such as found on lawn mowers do not use filters even though they are subject to combustion contaminates because they use a sling type oiling instead of pump style pressure.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #9 of 19 (permalink) Old 03-30-2014, 11:42 AM
tdkkart's Avatar
Fine time to bring up the point that this is why you shouldn't use engine oil, IE:the MoCo's SYN3, in transmissions and chain/clutch cases, and it has to do with detergent vs non-detergent oils.
Detergent oils: "Detergents" are chemical additives that pick up and carry foreign materials in suspension so that they can be filtered or flushed away. This is how your laundry or dish detergent works, it picks up the proteins and solids that the stains are made of, holds them in suspension and floats/carries them away with the water when it drains.
Detergent motor oils do the same thing, they pick up the foreign materials and contaminants and carry them to the filter where they get removed rather than being circulated continuously through the bearings and other tight tolerance areas of the engine. If there's no filter, it continues to carry the junk around through your motor.
Non-detergents do not have that additives that suspend and carry the contaminants. Anything produced by the engine or trans, or introduced from the outside falls out of suspension and ends up laying in the bottom of the cases. While it doesn't get filtered out, it also doesn't get continuously circulated through the gears and bearings either.
So, you decide. Most oils used in transmissions, gear cases or other non-filtered applications are non-detergent, most engine oils are heavy in detergents.
Which is the proper oil to use in your engine and which in your transmission??
tdkkart is offline
post #10 of 19 (permalink) Old 03-30-2014, 12:52 PM
I do agree, but could be getting at the pressure plate debri and the greyish coloration of the primary oil (hydraulic), what ever happened to straining snythetic thru a loaf of freach bread? then reusing it. Just out there
reds4 is offline
Transmission fluid into primary Lima14 Engine Related 38 10-30-2018 12:47 PM
Chrome Primary Cover, Rocker Boxes, Cam Cover, Transmission Side and Top Covers, merritta Parts for Sale 1 04-20-2018 05:03 PM
M8 Transmission / Primary issue. POW-MIA *General Road Glide Discussions/Pictures 14 09-13-2017 12:49 PM
New narrower transmission / primary cover on Ultra Low scbenoit Fluids and Lubricants 16 07-03-2017 12:16 AM
Primary and transmission fluid question ? Road dawg Tech Area 14 06-22-2013 07:49 AM
