Red Line Product Users - Road Glide Forums
post #1 of 20 (permalink) Old 04-04-2014, 06:27 AM Thread Starter
I realize there are many opinions on Eng/Primary/Trans oils, but I am interested in users of Red Line engine and primary oil users(I have used Red Line in my trans and am very happy with it). I would like opinions on your satisfaction with Red Line engine and/or primary oil or any issues you may have had.
Thanks
FLTRXS20 is offline
post #2 of 20 (permalink) Old 04-04-2014, 07:47 AM
Hullhorr's Avatar
I've been using Redline in all 3 holes since my first oil change. I have stopped using the primary fluid and replaced it with ATF at the recommendation of Rivera Primo since installing their clutch last summer.
No issues with their fluids. I will continue using it in the engine and transmission
2009 FLTR MOP
Hullhorr is offline
post #3 of 20 (permalink) Old 04-04-2014, 08:50 AM
arkieglide's Avatar
Tranny fluid with shockproof is great and engine oil is fine, but I had slippage issues using their primary fluid. Went back to standard Harley primary fluid.
2011 RG Ultra Brilliant Silver Pearl
arkieglide is offline
post #4 of 20 (permalink) Old 04-04-2014, 09:39 AM
Myself along with seven other fellows riders are using the Redline products in all three holes. Very satisfied.
inferno1976 is offline
post #5 of 20 (permalink) Old 04-04-2014, 09:55 AM
hd4cruzin's Avatar
Been using Redline products in all 3 holes since 2005 with no problems.
2012 FLTRX BBP
hd4cruzin is offline
post #6 of 20 (permalink) Old 04-04-2014, 10:14 AM
I've been using Red Line in engine, trans & it works for me. But I used in primary & my clutch started to slip. I went back to HD Formula+ & the problem went away. I don't mind paying the money for there products, they work. Check this out:
http://syntheticoil-europe.eu/162-es...ter_synthetic#
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #7 of 20 (permalink) Old 04-04-2014, 10:30 AM
1st Sgt's Avatar
Been using Redline MT 90 for my sports car tranny - 150000 miles without missing a beat. Run Redline in all 3 holes on the 2011 RGU. I did have an issue with the clutch slipping but couldn't tell you if it was due to the oil as I've got a bit more HP than stock and since the slippage was only in 5th gear at higher rpm were the power really came on the pipes, I wasn't inclined to think it was the oil. (I believe that if it was an issue with the oil, slipping would have been present in all gears across the rpm range)
And while Redline engine oil is more expensive than Mobil 1, I like it and feel that it offers more protection and heat tolerance and will continue to use it. Plus Redline has more zinc in it than Mobile 1 (If I could find that chart that showed the breakdown comparison I would have attached it but...)
1st Sgt is offline
post #8 of 20 (permalink) Old 04-04-2014, 01:54 PM Thread Starter
All, thanks for the replies.
FLTRXS20 is offline
post #9 of 20 (permalink) Old 04-04-2014, 02:31 PM
The Volusianator's Avatar
Cool that you're keeping track!
hd4cruzin, which number are you
The Volusianator is offline
post #10 of 20 (permalink) Old 04-04-2014, 03:48 PM
Easyryder01's Avatar
Redline in all 3 holes and will not use Mobil 1 again. Love the stuff.
2017 RGS Velocity Red
Easyryder01 is offline
Fuel Moto Product Users FLTRXS20 ECM/Fuel Management systems 23 03-11-2015 10:57 PM
red line oils dp1961 *General Road Glide Discussions/Pictures 18 05-10-2012 01:14 AM
Red Line Oil Radioactive *General Road Glide Discussions/Pictures 28 09-25-2011 10:44 AM
Red Line Oil JacktheBagger Engine Related 7 07-02-2011 09:03 AM
Anybody out there running Red line oil in their bike? vontoughguy *General Road Glide Discussions/Pictures 8 08-24-2010 03:30 PM
