When to switch to synthetic? - Road Glide Forums
post #1 of 12 (permalink) Old 04-11-2014, 05:59 PM Thread Starter
PAVEMENTPILOT's Avatar
O.K., another dumb oil question. I'm coming up on my 5k service and feel after reading some of the forum post's that switching from petroleum oil over to synthetic could benefit my '13 RGU. After speaking to an Indy wrench, he stated it would be more beneficial to the top end of the engine to stay with petroleum for at least 8-10k miles. I might add that this is the first new Harley I've owned. All others were used and already running synthetic. Any input would be greatly appreciated.
PAVEMENTPILOT is offline
post #2 of 12 (permalink) Old 04-11-2014, 06:10 PM
You can run synthetic anytime. I started putting in the synthetic after my 1k service and havent looked back since. Im pretty sure the indy said that because new motors need time to break in if you will but again i wouldnt worry about it since you already have miles on it
post #3 of 12 (permalink) Old 04-11-2014, 06:10 PM
I switched at the first oil change(1,000 miles) and the dealer did the switch as the first oil change was on them. They did not indicate that it would be an issue. My bike is a 09, so maybe the newer bikes would be different. You could look at your owners manual to see if it states what should be done. There are many on here that are more knowledgeable than I and do engines for a living, so I am sure others will speak up.
FLTRXS18 is offline
post #4 of 12 (permalink) Old 04-11-2014, 07:13 PM
Changed mine over at 5k.
Big_gary is online now
post #5 of 12 (permalink) Old 04-11-2014, 07:28 PM
I changed mine at 1k and would have done it sooner, but I was to busy having fun the first couple of days.
Sent from my SPH-L710
post #6 of 12 (permalink) Old 04-11-2014, 07:46 PM
At 1K I went with Red Line Shock Proof
Ran HD Dino until 5K & changed to Red Line 20/50W
I tried Red Line Primary & but clutch started to slip & then went back to HD Formula+ & have not had anymore problems.
There are many good Syns out there. Here is why I like Red Line:
http://syntheticoil-europe.eu/162-es...ter_synthetic#
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #7 of 12 (permalink) Old 04-11-2014, 09:18 PM
1st Sgt's Avatar
Changed to synthetic at 1000 miles - if I had to do it again, I would do exactly the same thing.
1st Sgt is offline
post #8 of 12 (permalink) Old 04-11-2014, 09:38 PM
The day I bought the bike I had the dealer change the oil. Been running nothing but AMSOIL in my bikes for the past 20 years and have never had a problem.
easybiker is offline
post #9 of 12 (permalink) Old 04-11-2014, 10:26 PM
tmd
You can put in synthetic the day it rolls off the saaembly line or never switch. Motor wont know the difference but your wallet may. Use whatever oil tickles your fancy. As long as its the proper grade and you change it regularly your motor will give you thousands of trouble free miles.
tmd is offline
post #10 of 12 (permalink) Old 04-12-2014, 04:58 AM
ybnorml's Avatar
Changed from dino to synthetic at 1k miles..
I'm at 72k miles with no engine issues....
Change oil and filter every 5k miles and enjoy the ride.
ybnorml is offline
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 07:18 AM
When & if to switch to synthetic??? Boomer13 Tech Area 30 05-15-2012 05:26 AM
Synthetic Oil jimmyray11349 Do-IT-Yourself 36 03-04-2012 09:47 AM
synthetic oil ameleo Do-IT-Yourself 6 06-30-2011 06:03 PM
Lucas "synthetic oil stabilizer" ybnorml *General Road Glide Discussions/Pictures 7 09-02-2010 03:38 AM
