Engine oil temp? At what temp do you pull over? - Road Glide Forums
post #1 of 36 (permalink) Old 05-12-2014, 12:19 PM Thread Starter
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Smile Engine oil temp? At what temp do you pull over?
At what engine oil temperature do you get worried?
Thanks Brice
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
post #2 of 36 (permalink) Old 05-12-2014, 12:39 PM
I guess with an oil cooler and fan this thought never crossed my mind, but since I'm curious I'm going to subscribe.
Sent from my SPH-L710
post #3 of 36 (permalink) Old 05-12-2014, 01:28 PM
PGR
PGR's Avatar
If I'm at highway speed, it's a non issue. it is, after all, an air cooled engine. If your oil temp gets high enough to even consider pulling over, you have problems that pulling over won't fix.
Last time I was rolling through the Badlands, it was 106 degrees, and the bike ran fine.
If I'm stuck sitting, like a train crossing, I switch the bike off. I also tend to avoid cities, so I don't get stuck in traffic. So for the OP, just don't go North East .......But if you do, just activate your EITMS.
Ron..........................
PGR is offline
post #4 of 36 (permalink) Old 05-12-2014, 03:03 PM
Don't sweat it. I've rode mine through the desert in Aug. +105 degrees at 90 to 95 mph, sometimes faster, from tank to tank. We would pull over when it started to rattle. Let it cool down & do it all over again. Never had any problems. I suggest you don't get a oil temp gauge, you'll be pulling over every 50 miles. That's why I have the extended warranty.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #5 of 36 (permalink) Old 05-12-2014, 04:10 PM
themensh's Avatar
Send a message via Yahoo to themensh
I've never worried about it. Now that my bike can shut down the rear cylinder if it gets to warm, I figure it is doing what it was designed to do.
Chuck
Do not criticize someone until your have walked a mile in their shoes. That way, when they get pissed off, you are a mile away and have their shoes...
themensh is offline
post #6 of 36 (permalink) Old 05-12-2014, 04:59 PM
Your quote about pulling over when it starts to rattle? Can you explain?
Azjosh is offline
post #7 of 36 (permalink) Old 05-12-2014, 05:17 PM
ameleo's Avatar
My oil temperature usually gets to 300 on my gauge here in sunny Florida where the outside temp is normally in the 90s. Lots of stop and go with the many traffic lights. Mothers day ride to Cape Coral and then down through Fort Myers beach, 300 degrees oil. No "rattling" or engine problems. Of course, tuned with Power Vision. I do know that my oil temperature is a lot higher with the Woods 555 cams then original with no cat, stage one air and Rush exhaust.
ameleo is offline
post #8 of 36 (permalink) Old 05-12-2014, 05:30 PM
Harleyagain's Avatar
Stop worrying and just ride it. This is not HD's first rodeo with heat management!
Bob
Harleyagain is offline
post #9 of 36 (permalink) Old 05-12-2014, 05:41 PM
I think he was talking about his brains
You'll over heat before the bike does.
post #10 of 36 (permalink) Old 05-12-2014, 06:01 PM Thread Starter
Smile High Oil Temps
I was watching my engine oil temp yesterday. Then started asking other guys with us what their temps were and was surprised by the variation in temps.
85*f temps. Bikes were all twin cam baggers 96ci-117ci. All the bikes are tuned and one way or another modified. 230* oil temp to 290* oil temps were seen. Every bike was heavily loaded running 45-90 mph roads 2 up.
Dino and synthetic oils were both in use.
SOOOO
I thought I would take a poll and see at what oil temperature you get nervous and at what oil temperature you pull over...
Please mention whether you are using Dino or synthetic...
Just seeing what everyone is comfortable with! :teeth:
I will go first! :
I am running dino 60wt engine oil and I am comfortable with the high of 230* I have seen.
I am thinking pulling over or changing riding style to lower temps at 285* would be prudent if I ever saw that temperature. I am not worried about the oil as much as head temps(valve seats) and bearing damage.
Before the heat of summer hits the wards fan and oil cooler fans will get mounted and set to turn on at 210* oil temp. Not for everyone but that is what I am comfortable with.
I have had an unbelievable amount of responses to this question on other forums and talking to buddies. I have now spoke to 3 different engineers about oil breakdown...
Universally with Dino oil they are nervous above a sustained 285* and on most synthetics 315* seems to be the cringe point.
First Time Dyno pull over the weekend. Stick_FSMC Dyno Results 3 03-30-2016 10:46 AM
103 Engine Oil Temp FLTRXS20 Engine Related 14 02-14-2015 10:36 AM
How do you pull the computer on 06 RG?? turbochrisb *General Road Glide Discussions/Pictures 3 08-09-2014 06:08 PM
Do I need a do-over on primary? xshovelfreak Troubleshooting for Road Glides 2 08-28-2012 09:55 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 02:53 AM
