Looking for Blue or green Primary fluid? - Road Glide Forums
LinkBack Thread Tools
Old 05-13-2014, 06:06 PM Thread Starter
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Question Looking for Blue or green Primary fluid?
I was thinking about primary fluid and clutch actuation today and can't remember what lube I saw that was blue or green being used so that you instantly knew where a leak was from...
Redline shockproof (red) in Tranny
20-50 or straight 60 (undied) in motor
Blue, green, ? in primary...
Any suggestions? Any color of wet clutch/compensator/chain lube thats not undied or red/pink.
Thanks, Brice
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
Old 05-14-2014, 10:03 AM
Do you have a leak?? You can buy dye and put it in if you are looking for the sorce of a leak.
Old 05-14-2014, 11:39 AM
kouack's Avatar
Valvoline vr1 synth is blue
kouack is online now
Old 05-15-2014, 06:13 PM Thread Starter
Smile oil colors
No leak...
I spent 15 minutes on my back on blacktop on a 87* afternoon helping a gentleman find his leak on a 09 streetglide with sin 3 in all holes...
I am going to redline in the tranny (pink), 60 wt syn amsoil in the motor (gold/brown)
And am thinking b&m trick shift (blue) in the primary...
Old 05-15-2014, 07:57 PM
Amsoil 60wt.
Originally Posted by Mountainman View Post
No leak...
Amsoil straight 60wt. is to heavy for the primary. Amsoil dealer here, the company does not recommend 60wt. in the primary.
Nevadasun
Old 05-15-2014, 08:58 PM
FDR's RGC's Avatar
Huh. Didn't say amsoil was going in the primary
FDR's RGC is offline
Old 05-15-2014, 09:05 PM
Have you been smokin 420??
2011 FLTRX 103 Sedona Orange
Hillglide is offline
Old 05-16-2014, 10:46 AM
Just because someone else had a leak doesn't mean you will. I wouldn't even worry about it until you have a leak and then only if you are having a hard time locating the leak would you use dye in the fluids.
In most cases leaks are easy to find.
Old 05-16-2014, 05:01 PM Thread Starter
Color coding
I am weird, the idea of having color coded lubes just in case gives me a warm fuzzy and reminds me of when I did it racing... Nothing like making something REALLY simple...
BTW Anyone using a 60 wt synthetic out there in HOT weather?
Old 05-16-2014, 08:22 PM
93-331-29psi's Avatar
You can put all the gold fluid you want in the oil hole and it's gonna turn black. I'm betting that b&m fluid will be black as well after about 500 miles.
Sent from Motorcycle.com App
93-331-29psi is offline
Primary fluid leaking at derby cover Shemp Troubleshooting for Road Glides 10 06-24-2015 11:14 PM
Primary fluid change. Funnel required? Lucas Fluids and Lubricants 31 04-25-2015 03:11 PM
primary fluid rcglider Fluids and Lubricants 41 04-26-2014 04:02 PM
Redline Primary Fluid Hullhorr Sold 9 01-12-2014 11:29 PM
Primary and transmission fluid question ? Road dawg Tech Area 14 06-22-2013 06:49 AM
