Additive for reducing carbon buildup - Road Glide Forums
post #1 of 22 (permalink) Old 05-27-2014, 08:55 PM Thread Starter
Anyone use an additive for reducing carbon buildup? I've heard people say additives are bad, curious what others are doing. Hoping to minimize carbon buildup and the problems that are associated with it. Thanks!
2012 FLTRX
Sideways is offline
post #2 of 22 (permalink) Old 05-27-2014, 09:42 PM
connector's Avatar
Not sure how to tell you but Twist the Throtle and no more carbon
09 FLTR 103 Stage III
connector is offline
post #3 of 22 (permalink) Old 05-27-2014, 09:48 PM
Unless you are running a very rich fuel mixture from an aftermarket tuner your motor probably will not get much carbon build-up. Most of the high octane fuel such as Shell Gold clean the engine as you drive it. But there are fuel injector cleaners which are fine to use. When I use them I usually go for a long ride to run the injector cleaner through. I feel uneasy about letting it sit for days or weeks in the tank and fuel lines.
grambo is offline
post #4 of 22 (permalink) Old 05-27-2014, 10:26 PM Thread Starter
No problems there!
2012 FLTRX
Sideways is offline
post #5 of 22 (permalink) Old 05-28-2014, 10:17 AM
FLTR2008Trike's Avatar
To lower carbon build up you need to remove the head breathers from being drawn into the intake and routed to a catch can. This will lower the carbon build up in the combustion chamber and on top of the pistons.
Loose valve guides or guide seals that leak, piston rings that dont seal well and too much fuel can contribute to carbon build up as well.
Seafoam & Marvel Mystery oil added in small amount with each fill up along with using quality fuel can help.
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #6 of 22 (permalink) Old 05-28-2014, 11:14 AM
Fuel additives are bad for the O2 sensors, STAY away from them and just run good fuel and make sure you have a good tune.
post #7 of 22 (permalink) Old 05-28-2014, 02:29 PM Thread Starter
Thanks for the replies. I'll look into routing the breathers externally. For now I'll just continue riding the crap out of it. I had an excessive amount of carbon buildup on the last top end on this bike, but it also used oil. It had enough carbon build up to cause piston to head contact. I know the tune is good and it runs really well, so I probably don't need to worry about it.
2012 FLTRX
Sideways is offline
post #8 of 22 (permalink) Old 05-29-2014, 02:54 PM
I have after market pipes with no O2 sensors and PCV. No need for them with a good tune.
easybiker is offline
post #9 of 22 (permalink) Old 05-29-2014, 07:17 PM
Lidflipper's Avatar
What happened to the old days when you would just squirt some ice water in the carb. It would send all the carbon out the tailpipe like shrapnel. I reckon technology makes everything better?
Mama told me I would meet people like y'all !!!
Lidflipper is offline
post #10 of 22 (permalink) Old 05-30-2014, 11:31 AM
Ice Water
I remember doing that.
2010 FLTRX,103 Stage 2,FullSac 2-1-2, black ceramic CB/Intercom, Power Vision
websterdan is offline
Any Suggestions About Reducing Energy Costs? Minimalist0124 General Off-Topic Discussions 7 02-02-2016 04:27 PM
reducing brake-lever travel palmpalm *General Road Glide Discussions/Pictures 5 04-21-2015 02:31 AM
Gas additive for winter vlgolf *General Road Glide Discussions/Pictures 31 11-02-2013 02:08 PM
Who uses Sea Foam or Star Tron additive? joke *General Road Glide Discussions/Pictures 30 11-25-2012 03:42 PM
