help oil light - Road Glide Forums
post #1 of 10 (permalink) Old 06-06-2014, 10:51 AM Thread Starter
help oil light
did oil change on my 2008 road glide now have oil light on. any help is appreciated.
teeboz is offline
post #2 of 10 (permalink) Old 06-06-2014, 10:56 AM
What oil filter did you use? Did you put oil in the engine and how much oil did you put in? What does your oil pressure gauge read?
post #3 of 10 (permalink) Old 06-06-2014, 11:34 AM Thread Starter
used 4 quarts 20w-50, all harley products including filter, pressure is reading 32, standard oil change nothing unusual.
teeboz is offline
post #4 of 10 (permalink) Old 06-06-2014, 11:54 AM
4 qts of oil is too much, you shouldn't put any more than 3 1/2 qts in the engine when doing a oil change.
But that isn't the problem, check the oil pressure sending unit and see if it is plugged in correctly.
Is it the oil light in the speed/tach bezel by the ignition switch or is it the engine light in the speedometer that is lit up??
The list of problems that will cause the oil light to stay on is
1-Improper circulation of the engine oil
2-low oil or diluted oil supply
3-problem with lamp wiring
4-faulty oil pressure sending unit
5-damaged oil pump
6-plugged oil filter element
7-incorrect oil viscosity
8-broken or weak spring in oil pressure relief valve
9-damage or incorrectly installed O-rings in engine
You may have got a bad oil filter try swapping out the oil filter and see what happens.
post #5 of 10 (permalink) Old 06-06-2014, 12:16 PM Thread Starter
it is the speed/tach bezel light the blue light that is staying on. checked the filter it def has oil going through
teeboz is offline
post #6 of 10 (permalink) Old 06-06-2014, 12:37 PM
Just because there is oil in the filter doesn't mean it is circulating properly. When doing a oil change it is the only item that is replaced that will affect oil flow.
post #7 of 10 (permalink) Old 06-06-2014, 01:05 PM
Isn't the blue light for your brights?
HogPro is offline
post #8 of 10 (permalink) Old 06-06-2014, 01:14 PM Thread Starter
dead on the money
hogpro you are dead on, for some reason my brights are showing up under the little oil can window.
you guys are the greatest.
teeboz is offline
post #9 of 10 (permalink) Old 06-06-2014, 01:38 PM
Good catch! The light bar in the bezel is in backwards.
post #10 of 10 (permalink) Old 06-07-2014, 09:00 AM Thread Starter
Yes have to turn it around thanls
teeboz is offline
Tri-Bar Light and Center-Mount Light Ernster500 Lighting 7 01-10-2013 06:51 PM
wonder bar light on my glide dosnt light my ride is a glide Troubleshooting for Road Glides 1 07-02-2012 08:18 AM
Engine Light and Batt Light come on at same time Hintontm Troubleshooting for Road Glides 8 05-12-2012 07:37 AM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 12:38 PM
3RD Brake Light/TourPak Rack & StreetGlide Rear Facia w/tail/stop light paco ritter Aftermarket Accessories 6 04-20-2011 11:00 PM
