NOT another oil thread. - Road Glide Forums
post #1 of 12 (permalink) Old 07-14-2014, 08:40 PM Thread Starter
I'm not looking for opinions on brands of oil or lubes, but rather opinions on the following: how likely is it that I'll get leaky gaskets by going with syn3 in all 3 holes. It's an 04 with 39k miles and I do not know what's been in it up to this point. I'm not sure if this oil is what I want to use, but I really like the idea of using one and don't mind spending more for synthetic, I just don't want to open a can of worms. Thanks.
PieDog is offline
post #2 of 12 (permalink) Old 07-14-2014, 09:28 PM
perrykw's Avatar
I am not using Syn 3, and I use a different weight in each hole, but I do use synthetic in all and have never gotten a leak. I'm at 11k miles and have been running synthetic since the first oil change.
perrykw is offline
post #3 of 12 (permalink) Old 07-14-2014, 09:38 PM Thread Starter
Thanks for the input.
Hoping to get some opinions or stories from people who switched to synthetic after 25k-50k miles on dino. I asked an old friend on fb who is Harley certified by MMI what I should run and the response was synthetic in all 3, but to check for leaks and change the gaskets if needed. That sounds like more than I'm willing to risk.
PieDog is offline
post #4 of 12 (permalink) Old 07-14-2014, 11:14 PM
I'm an Amsoil dealer. Been running Amsoils 20w-50 for 50,521mi. No leaks......
post #5 of 12 (permalink) Old 07-14-2014, 11:37 PM
tmd
Switching brands or types of oil is NOT going to cause a seal to leak. Just make sure your using the correct grade and you will be fine.
tmd is offline
post #6 of 12 (permalink) Old 07-14-2014, 11:41 PM Thread Starter
Thanks again for the input.
So, is the whole "if you ran dino for a long time (40k miles) and then switch to syn you'll have leaks" an old wive's tale? I'm not worried about mixing the tow, I'm just worried about gaskets leaking if it's never had syn.
Thanks again, and sorry of this is ignorant, and/or already beaten into the ground.
PieDog is offline
post #7 of 12 (permalink) Old 07-15-2014, 06:51 AM
tmd
With almost 30 years in the maintenance field I'm saying it's a false rumor.
tmd is offline
post #8 of 12 (permalink) Old 07-15-2014, 07:38 AM
Not to worry,
According to the "Material Safety Data Sheet" for H-D's SYN3, it is chemically a blend of 60% synthetic and 40% petroleum oils.
This is not illegal but it's certainly deceptive. The Courts have ruled that it is legal to advertise a product that has a chemical composition that includes at least SOME synthetic properties as a "synthetic lubricant".. in the case of SYN3, that oil is a 60/40 blend and not a true, 100% synthetic or anything even close to it.
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
post #9 of 12 (permalink) Old 07-15-2014, 07:49 AM Thread Starter
Originally Posted by tsigwing View Post
Not to worry,
Thanks for the info. Not set on a brand yet, but I would like to go FULL synthetic in all 3 unless there's some good reasons not to.
PieDog is offline
post #10 of 12 (permalink) Old 07-15-2014, 08:02 AM
I started out on syn3 in all 3 holes and service dept said to use forumla+ in trans. Made compensator sound better at start up.
bigdoug1130 is offline
Not another clutch adjustment thread. Dvs624 Engine Related 9 10-19-2017 04:00 PM
Not just another windshield thread... thealaskan Windshields 0 10-16-2015 10:56 PM
Another Oil Cooler Thread Tackdriver Aftermarket Accessories 6 08-17-2014 09:49 PM
Not another oil thread.... tmd General Off-Topic Discussions 2 04-11-2013 05:18 AM
Not another tire thread... Wharf Rat Wheels and Tires 6 09-28-2012 09:10 AM
