Barnett's advice on Primary - Road Glide Forums
post #1 of 6 (permalink) Old 07-25-2014, 02:06 AM Thread Starter
mitchdm's Avatar
Well on the Scorpion, still barking like a pup on take off. I called Barnett to see what fluid they recommend.
Their advice was the ATF with Dexron provided the smoothest engagement of their clutches.
So I changed the primary fluid and the engagement is smoother and no more barking like a pup.
Just thought I would let ya know.
mitchdm is offline
post #2 of 6 (permalink) Old 07-25-2014, 09:07 AM
spokanebagfan's Avatar
If you ever need another one or can't find the brand you want check out B&M trick shift. it is and ATF as well and used in a lot of high end race builds.
spokanebagfan is offline
post #3 of 6 (permalink) Old 07-25-2014, 09:35 AM
Trak350's Avatar
I use type F for my Barnett clutches. That's what the instructions recommended.
"Be polite, be professional, but have a plan to kill everybody you meet." Gen. James "Mad Dog" Mattis (USMC)
Trak350 is offline
post #4 of 6 (permalink) Old 07-25-2014, 12:45 PM
On my '83 shovel I run the clutch dry with the factory belt drive. With Barrnet plates and springs I don't know how it could do anything but be off or on. lol
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #5 of 6 (permalink) Old 07-25-2014, 04:25 PM
JacktheBagger's Avatar
I've used B&M trick shift as well , works great
JtB
2011 Ultra
JacktheBagger is offline
post #6 of 6 (permalink) Old 08-09-2014, 09:34 PM
bigskyroadglide's Avatar
Trick shift on my Barnett. Works great
48 states, 19K miles, 23 days
Hoka Hey Rider #622
2011
bigskyroadglide is offline
Barnett Clear Derby Cover Lu Aftermarket Accessories 5 05-29-2014 10:09 AM
Barnett Clutch Mike Jesse Engine Related 0 03-10-2012 11:14 PM
Barnett Scorpion Clutch Ruggerbk Tech Area 0 02-24-2012 07:49 PM
Barnett clutch RoadGlide0611 *General Road Glide Discussions/Pictures 8 10-09-2011 08:12 AM
For sale: New +8 Barnett clutch cable SickRick Classifieds Archive (3 months old+) 0 09-19-2011 10:58 AM
