What type of O-ring is on the engine drain plug? - Road Glide Forums
post #1 of 17 (permalink) Old 07-25-2014, 06:41 PM Thread Starter
Changing oil and it looks like a rubber O-ring but can't tell. Can I use a copper one from Auto Zone?
spender9 is offline
post #2 of 17 (permalink) Old 07-25-2014, 07:18 PM
No, but if no other neoprene type to be had you can use teflon tape wraped several times around the goove area to simulate. Have done this a few times, don't over reef on the 5/8' plug ever.
reds4 is offline
post #3 of 17 (permalink) Old 07-25-2014, 07:29 PM
mjsdouble's Avatar
I've been getting O-rings from the hardware store. They work just fine.
mjsdouble is offline
post #4 of 17 (permalink) Old 07-25-2014, 07:50 PM
TimmyG's Avatar
I reused mine
TimmyG is offline
post #5 of 17 (permalink) Old 07-25-2014, 08:38 PM Thread Starter
Thanks for the information guys. Off to the hardware store.
spender9 is offline
post #6 of 17 (permalink) Old 07-25-2014, 08:46 PM
torqu's Avatar
There is a thread started on the forum. It lists part numbers from McMaster Carr. You can buy 100 of them for right around $12.00
torqu is offline
post #7 of 17 (permalink) Old 07-25-2014, 09:58 PM
1st Sgt's Avatar
If it's inside diameter is 7/16 and it's outside diameter is 9/16, how can it only be 1/16th of an inch thick? Just wondering...
1st Sgt is offline
post #8 of 17 (permalink) Old 07-25-2014, 10:00 PM
1st Sgt's Avatar
Never mind - it's been a long day....
1st Sgt is offline
post #9 of 17 (permalink) Old 07-25-2014, 10:05 PM
mjsdouble's Avatar
I shoulda took you with me to the hardware store. I couldn't get away from the guy helping me. He's been working there WAY TOO LONG. I'm sure he has your answer. It'd be good to see you and your GoPro at SW. Are you going?
post #10 of 17 (permalink) Old 07-26-2014, 03:24 PM
mike's Avatar
One would like to think its a $8 90 durometer Viton or a silcone material to withstand the massive heat and pressure requirements of the Twin Cam engine.
However I'm pretty sure it a generic 75 durometer #18 nitrile o ring avail everywhere. I reuse mine a lot also, if they look ok and not nicked.
Never had a drip yet.
I reject your reality, and replace it with my own..
2007 FLTRI
mike is offline
Stripped out drain plug threads rlaf75 Troubleshooting for Road Glides 16 10-30-2015 11:44 AM
drain plug pauld Fluids and Lubricants 11 06-08-2015 08:42 PM
Oil Drain Plug Size (threads) JRB_RME5 Do-IT-Yourself 0 12-29-2014 09:28 PM
Primary drain plug has a lot of metal shreds fat boy ultra Troubleshooting for Road Glides 8 05-14-2013 12:45 AM
Drain Plug O-Rings MidniteRyder *General Road Glide Discussions/Pictures 32 03-19-2013 08:21 AM
