Harley/Baker 5.5 quart oil pan - Road Glide Forums
post #1 of 7 (permalink) Old 07-26-2014, 09:19 PM Thread Starter
Has anyone put this new oil pan on their Glide? I went and looked at a the Indian dealership and their bikes come with 5.5 quart pan.
I live in FL and it is hot. I know greater oil capacity would help.
Thoughts? Thanks
2012 road Glide Ultra, FM 107, 777 cams, and Stage B heads. Street Glide wheels from 2014. DDM HID headlights, tour pack release kit, LED lights on tour pack.
JSFRGU is offline
post #2 of 7 (permalink) Old 07-26-2014, 09:55 PM
Punishher7's Avatar
Literally millions of trouble free miles on stockish HD power trains. No need to fix an imaginary problem. I for one have an oil temp gauge and run Lucas fluids and have learned to not watch the guage....
2013 RGC
Punishher7 is offline
post #3 of 7 (permalink) Old 07-27-2014, 08:53 AM
skratch's Avatar
Thoughts? Thanks
the oil temp is still going to reach the same temp. it's just going to take longer to get there.
skratch is offline
post #4 of 7 (permalink) Old 07-27-2014, 09:14 AM
I spend enough money on oil ($40+) when doing engine oil changes (not counting the primary and trans) I sure don't need to buy another 2 qts of oil for each oil change.
As mentioned the oil will still get just as hot running the bigger oil pan so there is no real advantage.
You would be better off investing in a better oil cooler instead.
post #5 of 7 (permalink) Old 08-09-2014, 01:26 PM
Not true at all. Bigger pan and more oil means the oil stays in the pan longer before being circulated back through the motor. This adds net cooling capacity to the system and will result in a a 15-20 degree drop in max steady state oil temps. It is a dry sump system, so it is more like an oil tank versus a pan, and it is exposed to the slipstream under the bike as well.
Smopho is offline
post #6 of 7 (permalink) Old 08-09-2014, 01:28 PM
pat123's Avatar
I was looking at one for my 124 but @ $800.00 they can keep it.
pat123 is offline
post #7 of 7 (permalink) Old 08-09-2014, 04:15 PM
skratch's Avatar
sounds good in theory, but there have been enough published unbiased test results that show the reality is a different animal.
if you want to spend the money on it, go for it. it's your ride and i'll not begrudge you one dime. me, i'll spend my money on something else, thank you.
skratch is offline
Baker +1.5 oil pan Darreldanger Engine Related 6 09-13-2016 05:11 AM
Speakers mb quart and inifinity jetdrvr Parts for Sale 5 05-13-2013 07:59 AM
Baker's +1.5 oil pan Bill Golightly Aftermarket Accessories 10 10-11-2011 09:39 AM
Baker Plus One Oil Pan 103_FBob Engine Related 10 07-28-2011 09:32 AM
Baker Plus One Oil Pan Tytanium Engine Related 0 05-17-2011 05:16 AM
