DOT 4 to DOT 5 Brake Fluid - Road Glide Forums
post #1 of 21 (permalink) Old 07-27-2014, 08:58 PM Thread Starter
Q-Hog's Avatar
Can I change out DOT 4 to DOT 5 brake fluid in the front brake line (ABS) by just bleeding it out and add the new fluid? I have manually bled my brakes (ABS) the conventional way after adding new brake lines and calipers before without any issue but I never did a complete swap out. I'm thinking it should be the same as bleeding it. Any advice? Thx
Q-Hog is offline
post #2 of 21 (permalink) Old 07-28-2014, 05:12 AM
Ohiobellboy's Avatar
Just curious why you're going to DOT 5 in the lines?
A.K.A OBB
Ohiobellboy is offline
post #3 of 21 (permalink) Old 07-28-2014, 06:46 AM
FrankieB's Avatar
I wouldn't switch it to DOT 5, it is a PIA to bleed all the air out. It also absorbs moisture like a sponge. Every time you crack a new bottle open the left over should be trashed.
06 RK
11 RGU
FrankieB is offline
post #4 of 21 (permalink) Old 07-28-2014, 08:11 AM
I switched a couple of classic cars I once owned from Dot 3-4 to Dot 5 about 10 years ago. The main advantages for doing this was that the fluid was paint friendly and hydrophobic so there was less internal system corrosion. I know FrankieB says it draws water but I swear it's the Dot 3 or 4 that is hydroscopic and has that issue otherwise there would be very little advantage to using it.
The down side was I was never able to get the brake pedal as stiff as it was with Dot 3 or 4 no matter how many times I tried to bleed the brakes. Dot 5 also likes to keep tiny bubbles in it so you have to be really careful to not overly agitate the bottle while adding it to your system. This may be extreme but I would allow the fluid to sit in the master cylinder over night after I filled them to allow the bubbles to come out before bleeding. That would turn bleeding the brakes into a multi day affair.
One other issue that was claimed at the time was that you should only convert to Dot 5 when switching out every bit of rubber in the system. That meant new hoses and new or rebuilt calipers and master cylinder. I have no idea if this is still the thinking but that's what I did on each car.
Jeff
Jeff396 is offline
post #5 of 21 (permalink) Old 07-28-2014, 10:13 AM Thread Starter
Q-Hog's Avatar
Thx guys. I put on a new brake line from the brake caliper to the abs box and a new PM 6 piston caliper. It didn't come with instructions regarding what type of DOT fluid to use, I later found out it required DOT 5 fluid. And I currently have DOT 3-4 fluid in it.
Q-Hog is offline
post #6 of 21 (permalink) Old 07-28-2014, 12:30 PM
tmd
DOT 3/4 absorb moisture. DOT 5 is silicon based and does not absorb moisture. On a side note DO NOT USE DOT5 if you have ABS. Supposedly it has to do with the boiling point. HD went from 5 to 4 when they offered ABS on their bikes.
Hematite likes this.
tmd is offline
post #7 of 21 (permalink) Old 07-28-2014, 01:11 PM Thread Starter
Q-Hog's Avatar
I'm glad you told me that. Thx..
Q-Hog is offline
post #8 of 21 (permalink) Old 07-28-2014, 05:46 PM
tmd
One other note about this. I don't remember if its going form 5 to 4 or 4 to 5 but the piston seals in one is different and the change will cause them to swell and lock your breaks.
tmd is offline
post #9 of 21 (permalink) Old 07-28-2014, 06:04 PM Thread Starter
Q-Hog's Avatar
Due to the ABS, I'm just going to go with DOT 4.
I'm surprised that There's not more comments on this topic since I see a lot of 6 piston calipers mounted on these RGs pics on the forum.
Q-Hog is offline
post #10 of 21 (permalink) Old 07-28-2014, 06:59 PM
Maybe they don't have the ABS on theirs. Dunno
A.K.A OBB
leaking brake fluid THEMASTERDESTROYER Fluids and Lubricants 16 04-11-2014 09:05 PM
Brake Fluid Leak lldsilver41 Tech Area 2 09-10-2012 02:28 PM
How often do you flush your brake fluid? jcanrun *General Road Glide Discussions/Pictures 12 05-08-2011 01:28 PM
head trip dot/non dot BAGDRAGGER Helmets 11 02-21-2011 04:07 PM
To DOT or not to DOT (give me a better option) 1BigGuy Helmets 19 10-10-2010 07:15 PM
