Different weight oil for winter?? - Road Glide Forums
post #1 of 8 (permalink) Old 11-04-2014, 04:55 PM Thread Starter
Just got some heated gear and plan on riding all winter in New England, as long as the roads are dry. My question: should I use different weight oil? Guessing most of the riding will be at air temps between 25 and 40.
Thanks.
PieDog is offline
post #2 of 8 (permalink) Old 11-04-2014, 05:10 PM
tmd
I've never ridden when its in the 20's but have plenty of times when its in the 30's and 40's. Haven't seen a need to switch to a different grade oil.
tmd is offline
post #3 of 8 (permalink) Old 11-04-2014, 07:43 PM
I've never had a problem with it being cold here in New England. I just let the bike warm up for a couple extra mins, if that long.
post #4 of 8 (permalink) Old 11-04-2014, 07:58 PM
miker717's Avatar
I ride year round. the 20w50 is fine. Just be careful of the mag chloride, it's worse than gravel. Very slick
2011 vivid black fltrx
miker717 is offline
post #5 of 8 (permalink) Old 11-05-2014, 08:51 AM
I would be more worried about salt or salt residue getting on the bike than the oil.
Anyone from the east and midwest knows what salt will do to a automobile and the bike would have the same problem. It is also harder to wash the bike in cold weather because the water will want to freeze so the salt will sit on the bike especially on the bottom of the bike.
Also when the sun comes out and the temps rise and melt water gets on the road that will have salt in it. The melt water will also freeze on the road when the sun starts to set and the temps drop causing extremely hazardous riding conditions.
I would recommend putting the bike away until spring but it is your decision.
post #6 of 8 (permalink) Old 11-05-2014, 10:20 AM Thread Starter
Thanks input about the oil weight. I'm going to stick with that weight (but will NOT open a can of worms by discussing which brand is best. HA!).
Thanks also for the concern for my bike, and safety. I've ridden throughout winter on "warm" days (32+) my whole life, so I understand what you saying, and adjust my riding accordingly.
PieDog is offline
post #7 of 8 (permalink) Old 11-05-2014, 02:55 PM
Exclamation Please Open That Can.
Originally Posted by piedog View Post
thanks input about the oil weight. I'm going to stick with that weight (but will not open a can of worms by discussing which brand is best. Ha!).
Thanks also for the concern for my bike, and safety. I've ridden throughout winter on "warm" days (32+) my whole life, so i understand what you saying, and adjust my riding accordingly.
not!!
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #8 of 8 (permalink) Old 11-05-2014, 11:24 PM
so cold
I have the gear and ride year round in South Dakota. I have started the day at 16 degrees and put in 300 miles. The others have warned about road hazards so I won't. You seem pretty sharp. Last year was the first year I ever switched down viscosity. I am glad I did. The MOFA recommends it and my experience is the bike starts better and rattles less. I use a quality synthetic (not Syn3). 10/40 is good to around 70 dgrees. Probably a bit less with lowers. I just did my winter oil change last weekend. I am good to go.
flattie, shovel, Evo, TC 88,96,103. I've not had 'em all, but I've had lots. '04'07'13 Sharks
El Camino Deslizarse is offline
Lowered Progressive Springs--Lower Weight Fork Oil? James Suspensions 8 05-20-2016 08:56 PM
Lowered Progressive Springs--Lower Weight Fork Oil? James Suspensions 0 04-11-2016 11:04 AM
2013 RG CVO Oil Type/Weight KillSwitch Do-IT-Yourself 15 09-27-2014 04:48 PM
Pro's/Con's for using heavier weight oil in trans bd1980 *General Road Glide Discussions/Pictures 10 10-02-2012 07:12 PM
Different year differences...That's a lot of different HogPro *General Road Glide Discussions/Pictures 2 04-20-2012 04:38 PM
