Primary fluid change. Funnel required? - Road Glide Forums
post #1 of 32 (permalink) Old 11-30-2014, 11:00 AM Thread Starter
Folks-
The 1000 mile fluid change was just accomplished on the 2015 Road Glide Special. Syn 3 was installed in the primary, transmission, and engine. (No change was noticed in performance or smoothness of shifting.)
Is there a special long funnel that allows this process to be easier? It seems a funnel was available for servicing the primary? Where would I find this tool?
Thank you!
Lucas
(In hot and dusty Phoenix.)
Lucas is offline
post #2 of 32 (permalink) Old 11-30-2014, 11:15 AM
Harley offers this http://www.harley-davidson.com/store...il-fill-funnel
not sure of any others but for a HD brand product this one is reasonably priced.
I havent used one but they look nice
Eagle is offline
post #3 of 32 (permalink) Old 11-30-2014, 11:25 AM Thread Starter
Primary oil funnel
Eagle-
Thank you! I'll order one!
Lucas
Lucas is offline
post #4 of 32 (permalink) Old 11-30-2014, 12:43 PM
Go to your local auto parts store and pick up a small narrow funnel for a buck or 2. No need to go to HD for a funnel
post #5 of 32 (permalink) Old 11-30-2014, 01:03 PM
Pattywagon's Avatar
Agreed with above ,its crazy to spend that much a MOCO when u can buy small funnel at any numbers of places a lot cheaper n can use for other basic funnel needs in the process. But to each their own . The MOCO gets enough of our $$$$$!!!
2013 FLTRX,8inch klockwerks,CFRknockoffs,11inch CC apes, screamin eagle 255 cams n adjustable pushrods, PC5, DYNOED 85.5 HP, 104 torque,SoCal HID's
Pattywagon is offline
post #6 of 32 (permalink) Old 11-30-2014, 01:31 PM
FDR's RGC's Avatar
I just lean it over and have the wife pour, but any small funnel will do.
FDR's RGC is offline
post #7 of 32 (permalink) Old 11-30-2014, 08:11 PM
moose1's Avatar
You can get a funnel at the dang dollar store for under a buck
2012 FLTRU vivid black
moose1 is offline
post #8 of 32 (permalink) Old 12-01-2014, 08:42 AM
Originally Posted by Lucas View Post
Eagle-
Lucas
It works well.
BIAMCHawkeye is offline
post #9 of 32 (permalink) Old 12-01-2014, 09:20 AM
Folks-
Thank you!
Lucas
Get the 20w50 out of the transmission and put in 75w90 or 75w140 gear lube in and it will improve the shifting. I have been using Mobil 1 75w140 or Valvoline 75w140 full synthetic gear lube in my trans since 2008 and I haven't had any problem yet.
The transmission is a gear box not a engine so use gear oil instead of engine oil.
Also HD SYN 3 oil is a synthetic blend and it is NOT a full synthetic oil. IMO full synthetic oil is best for the engine.
+1^^^
A long stem funnel from the auto parts is what I use, I think it was only a $1 or $2 and it works great.
post #10 of 32 (permalink) Old 12-06-2014, 10:09 AM
jim540's Avatar
If you don't want to get a funnel you could cut the side out of a plastic jug and make a piece to slide into the derby cover opening. This will give you something to pour into.
2011 RGC, 103 engine, custom seat, Drogo's Dragula exhaust, Drago's 565 cams, ported and polished heads, HD Heavy Breather intake, Thunder Max tuner, Heritage style bars, Hawg Wired Six Pack audio system, Mean City Cycles modified seat ΜOΛΩΝ ΛΑΒΕ
jim540 is offline
Tags
engine , oil , primary , syn 3 , transmission
Looking for Blue or green Primary fluid? Mountainman Fluids and Lubricants 11 07-08-2014 07:14 PM
primary fluid rcglider Fluids and Lubricants 41 04-26-2014 04:02 PM
Redline Primary Fluid Hullhorr Sold 9 01-12-2014 11:29 PM
Primary and transmission fluid question ? Road dawg Tech Area 14 06-22-2013 06:49 AM
Fill and Go Fuel Tank Funnel?? wachuko *General Road Glide Discussions/Pictures 13 05-28-2011 09:43 PM
