Redline oil - Road Glide Forums
post #1 of 11 (permalink) Old 03-16-2015, 07:45 PM Thread Starter
emptyking's Avatar
Redline oil
I know I'm beating a dead horse here but had a questions about redline oil as I am a first time user. So first this is my first time changing my oil myself and do not have a manual. I have a 2008 RG and put 4 quarts is the engine, 1 quart in the tranny and I used 32oz in the primary. Now I've read that with the 6 speeds they say to use 38oz but when I called the Harley dealership they said to only use 32oz. I guess I may just be paranoid being my first time changing my oil myself, but it seems the bike is running a bit hotter. And a little worried about the primary. Any info would be great thanks guys.
emptyking is offline
post #2 of 11 (permalink) Old 03-16-2015, 07:58 PM
RGKen's Avatar
It's 38oz for a normal fluid change. If you ever remove the outer primary so that all the oil is drained you need to add 45oz. It is better to have a little less in the primary than over filling.
2018 FLTRXS
RGKen is offline
post #3 of 11 (permalink) Old 03-16-2015, 08:10 PM Thread Starter
emptyking's Avatar
So then do you think 32oz is ok then? That's what the dealership is telling me.
post #4 of 11 (permalink) Old 03-16-2015, 08:48 PM
Open the derby cover and check that the clutch is bathed in oil. If not add some. 38oz is the correct number unless you pull the primary. I buy one extra bottle and it lasts a few changes.
2013 Ultra
Pics here:
rg_dave is offline
post #5 of 11 (permalink) Old 03-16-2015, 08:49 PM
Hullhorr's Avatar
I would add another 6oz. The compensator has trouble getting enough lubrication even with the correct amount of fluid.
2009 FLTR MOP
Hullhorr is offline
post #6 of 11 (permalink) Old 03-16-2015, 09:00 PM
PAVEMENTPILOT's Avatar
If in doubt, just go to YouTube and in the search bar type in "2008 Road Glide primary case oil change". It shows you step by step. Good luck!
PAVEMENTPILOT is offline
post #7 of 11 (permalink) Old 03-16-2015, 09:10 PM
EZMotoTim's Avatar
I think you should have put 3-1/2 qt. of oil in the crank case. That's what I do. If it starts spitting oil out of the air cleaner, you put in too much.
2017 FLTRXS, Givi V56 Topcase, Windvest 10", National Cycle Hand Deflectors, Rapid Transit Tank Bag. My last bike was 2014 Triumph Trophy SE. Before that: 2010 FLTRX.
EZMotoTim is offline
post #8 of 11 (permalink) Old 03-17-2015, 05:21 AM Thread Starter
emptyking's Avatar
Thanks for the info guys. I defiantly did hit up YouTube that's where I saw the 38oz. So I think I'm going to add more primary fluid and I'm going to keep an eye on the oil to see if it's spitting out the air cleaner. Thanks again
post #9 of 11 (permalink) Old 03-29-2015, 07:36 AM
ACESnEIGHTS's Avatar
I agree 3 1/2 quarts in crank case, not sure why HD insists it's 4qts. If I put 4qts in it would puke oil out of the breather.
ACESnEIGHTS is offline
post #10 of 11 (permalink) Old 03-29-2015, 12:06 PM
The first thing you should do is go get a HD service manual for your year/model bike.
38 fl oz is the correct amount in the primary also the suggestions on the engine oil is correct 3 1/2 qt of oil max in the engine when doing a engine oil and filter change.
Use 75w90 or 75w140 full synthetic gear lube in the transmission Mobil 1 or Valvoline is good products to use, don't use 20w50 engine oil in the transmission even though the HD service manual tell you to.
Redline Oil JacktheBagger *General Road Glide Discussions/Pictures 13 09-08-2012 06:51 AM
Redline Oil Xaran *General Road Glide Discussions/Pictures 50 08-24-2012 05:03 PM
Redline oil BklynRGU *General Road Glide Discussions/Pictures 11 08-23-2012 10:07 PM
Redline oil ksarauer *General Road Glide Discussions/Pictures 5 06-01-2012 06:24 PM
Call Me Crazy , Redline Oil Q JacktheBagger *General Road Glide Discussions/Pictures 2 05-10-2012 03:03 PM
