$8 question - Road Glide Forums
post #1 of 13 (permalink) Old 04-15-2015, 05:30 PM Thread Starter
Blackbag1's Avatar
$8 question
Background: I'm about to change out the lube in all three holes again. My intention is to change it out every 5000-miles...engine, transmission, and primary. My '15 RGS cruises at a steady 3000rpms ALOT for a constant 2hrs every day 'cuz that's my commute on a lightly trafficked freeway...set the CC, settle against the backrest, boots up on the highway pegs, and enjoy the ride
Question: Is the $8 derby cover paper gasket (part# 25416-99C) a one-time use only item? The last time I changed out the primary fluid at its first 1000mile checkup, the gasket looked new-like but the red silicone bead was less proud than a new one. Would it be OK to apply a fresh bead of silicone/rtv on this used gasket and reuse it one more time?
The reason: $8 is still $8. That's about 2.42gals of 91octane ...about 80miles worth of additional high-speed miles traveled on said commute
Ok...but seriously...is it a one-time use only gasket?
2015 Vivid Black FLTRXS...ridin' dahellouttavit (27k miles...and still counting!!!)
"I'm not talkin' about pleasure boatin' or day sailin'. I'm talkin' about workin' for a livin'. I'm talkin' about sharkin'." - Quint
Blackbag1 is offline
post #2 of 13 (permalink) Old 04-15-2015, 05:39 PM
mjsdouble's Avatar
I service mine every 5k as well. I've reused it each time and I haven't had any issues. The covers been off 7-8 times now. I'm doing the same with my wife's bike with no problems.
SWIII, SWIV, SWV, SWVI & SWVII
mjsdouble is offline
post #3 of 13 (permalink) Old 04-15-2015, 06:23 PM
Yeah, I just reuse it if in is it good shape.
2013 Ultra
Pics here:
rg_dave is offline
post #4 of 13 (permalink) Old 04-15-2015, 06:30 PM Thread Starter
Blackbag1's Avatar
This is good to hear...thanks! Did you guys apply a thin bead of rtv or did you re-install it as-is with its less proud bead?
post #5 of 13 (permalink) Old 04-15-2015, 06:47 PM
I still got my original on and plan on keeping it until it leaks. NO RTV.
Big_gary is online now
post #6 of 13 (permalink) Old 04-15-2015, 06:50 PM
Smarty's Avatar
Ever since they went from the rubber o-ring to the gasket that covers the whole derby cover, no leaks. I've been using mine for about 60,000 miles and no problem.
Smarty is offline
post #7 of 13 (permalink) Old 04-15-2015, 06:51 PM
tmd
Use it as is. I've gone as much as 40k on the same gasket changing oil every 5k and never had an issue. Don't know how many more uses I could have gotten out of it because I sold the bike at that time.
tmd is offline
post #8 of 13 (permalink) Old 04-15-2015, 07:13 PM
Ok stupid question. When did they go back to a paper gasket for the derby cover? My 09 has the rubber o-ring
post #9 of 13 (permalink) Old 04-15-2015, 07:24 PM
mjsdouble's Avatar
I can't remember if my wife's 07 had the rubber o-ring or not. I changed her cover and it uses the paper gasket. I do know my '12 came with the paper gasket.
The same ole flattened "less than proud bead" still does it's job lol. No need to add anything to it.
post #10 of 13 (permalink) Old 04-15-2015, 08:22 PM
My 08 has a paper gasket. I reuse the derby cover gasket all the time, I only replaced it once just for the hell of it.
You shouldn't use any silicone on the gasket at all. Also I recommend that you replace the OEM Torque Head derby cover screws with Allen Head screws you will be glad you did.
Speaker Question (not a fitment question) FLTRXS18 Audio 9 12-31-2014 01:58 PM
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
