Full service questions - Road Glide Forums
  • 1 Post By Big_gary
post #1 of 8 (permalink) Old 11-16-2015, 06:59 PM Thread Starter
Mooseinthetub's Avatar
Hey guys, first post here. Bought a 15 RGS a few weeks ago and being the gearhead I am, I plan to do all my own services like I do on all of my machines. I am a mechanic by trade, on just about everything, from my farm equipment to the wind turbines I service at the day job. I am, however, new to motorcycle maintenance. Im sure its not much different from alot of the machines I work on, but Id rather be safe than sorry. I prefer to use Valvoline oil in everything I own. I have read alot of posts about oils through this forum and my question is can I use the same 20w-50 oil in the crank case, transmission and final drive? Or am I looking at different oils for each of them? Any help would be great and thanks in advance.
Mooseinthetub is offline
post #2 of 8 (permalink) Old 11-16-2015, 07:08 PM
I use gear lube (red line with shock proof) in the transmission. It's safe to use that engine oil in all three holes but there's better choices. I also perfer synthetic
Oils over Dino.
Big_gary is online now
post #3 of 8 (permalink) Old 11-16-2015, 07:55 PM Thread Starter
I would be using a full synthetic. If i chose to use a gear lube in the transmission, 75-140 is the correct weight to use? I'll look into the oil you mentioned and see if I can better educate myself on it before I pull the trigger on it.
post #4 of 8 (permalink) Old 11-16-2015, 08:15 PM
It sounds like you are mechanically adept. What I would suggest however is to invest in the Harley Service Manual. Your skills plus a $60 book and you will be good to go.
Jhl192 is offline
post #5 of 8 (permalink) Old 11-16-2015, 08:15 PM
bucketlisthd's Avatar
Prolly any 20/50 synthetic in the engine is fine. They run hot. I use Mobil 1 in the engine, Mobil I gear oil in the trans for me.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #6 of 8 (permalink) Old 11-16-2015, 08:16 PM
Yes, 75/90, or 75/140 both work well. I prefer Red line shock proof lube 75/250 because it's thick enough to obsorb gear noise but flows like a 75/90 oil. Been using its for decades in many different types of gear boxes.
EODHOG likes this.
post #7 of 8 (permalink) Old 11-16-2015, 08:29 PM Thread Starter
Great, thanks for the help everyone.
post #8 of 8 (permalink) Old 11-16-2015, 08:45 PM
Smarty's Avatar
I agree with this 100%! A good 20/50 synthetic in the engine and primary and you will be good to go..
Smarty is offline
Are all Full Face Helmets Made in China? BillyBob Helmets 37 09-16-2018 10:37 PM
First Full Fluid Service since Purchase BILBO Fluids and Lubricants 18 03-19-2014 02:42 PM
5000 mile service questions HogPro *General Road Glide Discussions/Pictures 12 11-20-2013 05:12 PM
couple questions (1k service, and other stuff) hometoast *General Road Glide Discussions/Pictures 3 09-12-2013 10:57 AM
1,000 Mile Service after the fact Questions Wildman *General Road Glide Discussions/Pictures 5 09-10-2012 10:25 PM
