Conventional to Syn - Road Glide Forums
 10Likes
post #1 of 30 (permalink) Old 11-18-2015, 11:56 AM Thread Starter
Sleepybagger's Avatar
Conventional to Syn
My engine builder recommended 2500 miles running conventional oil. I changed the oil at 250 & 500 and now at 2200 to Red Line 20/60 and call me crazy but I could notice a difference.
Okay lets hear it.
EODHOG likes this.
2015 113" 125/131
Sleepybagger is offline
post #2 of 30 (permalink) Old 11-18-2015, 12:23 PM
teejay's Avatar
What difference did you notice?
tom
teejay is offline
post #3 of 30 (permalink) Old 11-18-2015, 03:13 PM
JacktheBagger's Avatar
Redline 20-60 year round for quite some time now , have outstanding used oil analysis on it . Runs quieter and I unscientifically think it runs a little cooler ..
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 30 (permalink) Old 11-18-2015, 03:39 PM
I don't know about the engine, but I run Redline in the transmission, it definitely made a difference there, shifting is much smoother and it's a lot easier to find neutral.
post #5 of 30 (permalink) Old 11-18-2015, 05:39 PM
100edition's Avatar
Exactly what debel said.:thumbup:
100edition is offline
post #6 of 30 (permalink) Old 11-18-2015, 07:23 PM
Smarty's Avatar
After the first 100 miles or so, the engine has done what needs to be done on break in with seating the rings and such. After that, you are good to go with synthetic oil.
Smarty is offline
post #7 of 30 (permalink) Old 11-18-2015, 08:54 PM
smitty901's Avatar
You can run syn from day one. Old myth about it not allowing the engine to break in. One that is never going to die.
Like more wear was placed on the engine doing worthless oil changes than just changing it on the normal maintained.
But nice thing about this country a man is free to da what ever he wants to his bike.
smitty901 is online now
post #8 of 30 (permalink) Old 11-18-2015, 10:41 PM
Smarty's Avatar
Partly true, but on initial break in, a little more heat in the engine is a good thing. Now days, most engine builder heat cycle the engines up to 3 times to build up heat then allow cool down. Will the engines of today break in with synthetic, of course they will.
Smarty is offline
post #9 of 30 (permalink) Old 11-19-2015, 09:54 AM
Didn't HD put SYN 3 oil in the CVO's right out of the factory??
RGKen likes this.
post #10 of 30 (permalink) Old 11-19-2015, 11:18 AM
DED HD's Avatar
Syn oil is usually more expensive. When you change oil that frequent during break in, i think it makes sense to use conventional oil for cost savings alone. I did the same when i was breaking in mine (250, 500, 1000), but switched to syn after 1,500 miles.
hook and EODHOG like this.
'10 Red Custom:
DED HD is offline
conventional oil stevee Fluids and Lubricants 7 04-18-2017 10:14 AM
HD standard oil or HD syn or Mobil 1 syn K.I.HSr Fluids and Lubricants 21 05-05-2015 09:52 PM
Amsoil 20-50 syn vs Harley 20-50 syn mach65 *General Road Glide Discussions/Pictures 40 04-22-2015 08:41 PM
Chaincase Oil - Syn back to dino? longrides Troubleshooting for Road Glides 1 05-30-2010 06:09 PM
