Dirty Clutch Fluid - Road Glide Forums
 2Likes
post #1 of 16 (permalink) Old 04-01-2016, 08:14 PM Thread Starter
Q-Hog's Avatar
Dirty Clutch Fluid
What can cause the clutch fluid in the master cylinder to look dirty?
Q-Hog is offline
post #2 of 16 (permalink) Old 04-01-2016, 08:28 PM
FDR's RGC's Avatar
Use.
smitty901 likes this.
FDR's RGC is offline
post #3 of 16 (permalink) Old 04-01-2016, 09:28 PM
Moisture and if new system the internals & cap
if Luke metric bikes just bleed it out & and lint free wipe the colauate and fall out out
Sometimes it just looks yellowish from...big word for sunlight
reds4 is offline
post #4 of 16 (permalink) Old 04-01-2016, 10:51 PM Thread Starter
Q-Hog's Avatar
Mine looks murky. I have a 2015 RG.
Q-Hog is offline
post #5 of 16 (permalink) Old 04-02-2016, 09:30 AM
What I've seen over the years, others too Iam sure
Having a couple hydraulic clutchs and ripping apart
parts bikes and garage finds
Brake fluid has an infinity for water and will colauate, the
milky your seeing and clogs up the orifices
it ant supposed to brake down, chlorinated and all
DOT 5 is not, but from a contaminated container and moisture
have seen too
The use is the action and little air bubbles if not bleed to pressure vacuum kinda,
Some cheap shit used (env. friendly or old seem to
to wanta thirst for moisture
Your case with a new system and no leaks probably, well I'd
just change it all out, flush once completed volume of fluid from known good fluid, then fill and bleed just as you would to new
Wear disposable gloves
Do it yourself and you'll know it's right
reds4 is offline
post #6 of 16 (permalink) Old 04-02-2016, 11:28 AM Thread Starter
Q-Hog's Avatar
Thanks, I plan on changing it but I was wonder if something might be wrong somewhere.
Q-Hog is offline
post #7 of 16 (permalink) Old 04-02-2016, 11:44 AM
Used a clear tubing to her old clear tuberware keeping the opening end in the org in al fluid drained into,
same way I've done in GA and here
if it sit to long in the steaming Ga heat, seen em
salt out
Definitely get those squermers out
and have some boiled peanuts for me
reds4 is offline
post #8 of 16 (permalink) Old 04-04-2016, 08:03 PM
maddmoe's Avatar
15RG has a recall on the Clutch system, have it checked out and your fluid replaced
Dont talk about it, Be about it !!!
maddmoe is offline
post #9 of 16 (permalink) Old 04-04-2016, 08:12 PM
Ohiobellboy's Avatar
Keep in mind that line runs down by your exhaust and is subject to heat cycles which can cause issues. I believe I've read every two years is a good time to change it out. I'll be doing mine and the rear brake fluid at the 15k service.
A.K.A OBB
Ohiobellboy is online now
post #10 of 16 (permalink) Old 04-04-2016, 08:32 PM Thread Starter
Q-Hog's Avatar
Ok. I had my checked out for the recall last year. I currently have 18k+ on it. I'll have then look at it again. When should I have the fluid drained and replaced?
Q-Hog is offline
M8 Clutch Fluid Bleed msquad Do-IT-Yourself 10 08-31-2018 08:23 PM
ABS and Clutch fluid flush 30glock Do-IT-Yourself 2 04-18-2018 01:40 PM
Clutch Fluid level question geo8866 Do-IT-Yourself 8 12-03-2017 09:42 PM
Bad clutch fluid from factory? Subic97 *General Road Glide Discussions/Pictures 4 09-16-2016 10:36 AM
Anchored//// Dirty in Texas Pixman General Off-Topic Discussions 2 05-08-2010 06:12 PM
