What clutch do I have? - Road Glide Forums
 2Likes
  • 1 Post By kouack
  • 1 Post By 303RG
post #1 of 4 (permalink) Old 05-04-2016, 10:41 PM Thread Starter
Jorluivil's Avatar
I did a little research but could not locate anything that would help me identify if my bike has a wet or dry clutch. I have a 2011 Road Glide FLTRX 103 Custom. How can I determine what type of clutch I have?
Jorluivil is offline
post #2 of 4 (permalink) Old 05-05-2016, 02:36 AM
kouack's Avatar
Bike is stock??? No mods? Wet clutch, dry clutch are usualy used in primary belt drive application.
SMOKENJOE likes this.
kouack is offline
post #3 of 4 (permalink) Old 05-05-2016, 07:24 AM
JacktheBagger's Avatar
With the wet clutch , the clutch has it's own separate oil bath , completely sealed from the motor or transmission oils . So if you pull the derby cover and see oil in there , it's wet .. If it's a shovelhead or older Harley or has an open primary , it's dry ..
Wet clutches wear better than dry clutches , also are much easier on your clutch hand in stop and go traffic , unless you have a slave cylinder added to it ..
Dry clutches grab better off the line , don't last as long as wet clutches , and as they wear , get noisier .. They are more common on the race track ..
2011 Ultra
JacktheBagger is offline
post #4 of 4 (permalink) Old 05-05-2016, 08:27 PM
Harley's last dry clutch on a touring model was in 1984. I still have the pressure tester in the tool box.
RGKen likes this.
2015 RGS, Danny Gray, Ness Bars, Banana Boards, Bassani B4, Cams, Heads, Power Vision Remap, Chrome Enforcers and other stuff.
USMC 1973-1995
303RG is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Clutch Wiz vs Burley easy clutch Trak350 *General Road Glide Discussions/Pictures 14 03-11-2014 09:21 AM
Hydraulic clutch line, for those that have had to change one. Big Dog Controls & Handlebars 0 02-07-2013 08:54 PM
Must read if you have arthritis:Variable Pressure Cluth for your CVO/hydraulic clutch Cmathias Controls & Handlebars 2 10-23-2012 08:18 AM
Do You Have a Strong Mind....Well Do Ya??? Nevadasun General Off-Topic Discussions 17 02-12-2012 10:22 AM
