Smell oil burning help - Road Glide Forums
post #1 of 5 (permalink) Old 07-08-2016, 03:40 PM Thread Starter
I have a 2012 road glide about 11k miles on it never any issues. Took it to a different harley dealer bc i was out of state. They changed the oil in all 3 holes. I had them put mobil 1 synthetic in 1st two holes and gear oil in the last one. Anyway after leaving the dealer while riding i smelled oil burning. I just figured maybe they spilled a little and didnt worry about it. Now a week later when i ride i still smell oil burning. The oil seems to be burning on the back break side under the exhaust cover. When i stop i can see smoke coming off the exhaust but dont see anywhere it could be dripping down on the exhaust from. I check the level in the primary it was at full sitting still on the kick stand reader. So i assume when i ride and it expands it is 2 full? Could it be shooting into my exhaust? Called dealer back they said bring it back and they will check. I live in texas this was adealer in aGA. Also after riding there seems to be a drip or 2 out the 2nd hole on same side. Figured they didnt change the ring on tue bolt and when it heats up oil thins out and drips a drop or 2. Any other thoughts why this could be?
WOOSAB is offline
post #2 of 5 (permalink) Old 07-08-2016, 05:14 PM
lil chief's Avatar
It could be coming out of the oil filler hole ( I think thats what you're describing) or, it could be dripping out of the air cleaner & down onto the exhaust as well.
Lil Chief
lil chief is offline
post #3 of 5 (permalink) Old 07-08-2016, 05:51 PM
See if the filled the engine oil too high. It could be blowing out into the air cleaner. I fill mine about 70% up on the hatched area on the stick.
post #4 of 5 (permalink) Old 07-08-2016, 11:15 PM Thread Starter
I just opened and closed the 2 holes on the back break side. I took some of the oil out so it's about 3/4 up the jiffy stand reader. I also wiped all the oil off the pipe and underneath. Going to go ride in the morning and see if the problem is fixed. Will report back thanks fellas
WOOSAB is offline
post #5 of 5 (permalink) Old 07-08-2016, 11:17 PM Thread Starter
Also took the air filter off. Barely any oil in it. Also no spots below it in the motor cleaned the air filter just so I can eliminate it as well after my next ride
WOOSAB is offline
I smell like oil Diverrick Engine Related 2 07-07-2016 05:53 AM
Burning smell, and amp shorting out. Any ideas why? Bubba Audio 6 04-12-2014 06:24 AM
oil smell & oil in air filter fat boy ultra Troubleshooting for Road Glides 6 04-11-2013 10:04 AM
HELP! Fish smell. ameleo *General Road Glide Discussions/Pictures 43 01-21-2012 04:23 PM
Burning oil!! Gonekat Engine Related 18 07-11-2011 07:11 PM
