What is the oil usage on a 103 per ? mile - Road Glide Forums
 6Likes
post #1 of 30 (permalink) Old 09-05-2016, 12:21 AM Thread Starter
vontoughguy's Avatar
Angry What is the oil usage on a 103 per ? mile
I have used up to a qt. in 1000 miles.
I'm being told a qt. every 1000 miles, that seems a lot of oil.
So if that is true in 5,000 mile you have already done a oil change.
Need feed back.
My motor has been pulled apart by dealer 5 times to repair problems. Have been using Syn3.
jjones
vontoughguy is offline
post #2 of 30 (permalink) Old 09-05-2016, 12:31 AM
PsychoCycle's Avatar
Let us know the year and how many miles on your bike. I run a 2009 with 50,000 miles and it does not use/burn oil. I do not have to add oil between oil changes but there is a huge difference between these bikes and their oil consumption as you will see as some of the guys chime in.
2009 Road Glide
Red Hot Denim with loads of extras
PsychoCycle is offline
post #3 of 30 (permalink) Old 09-05-2016, 12:56 AM
My 2013 RG does not use any oil either. I think I added a very small amount once, but over all it is not an issue. Bike has 25K on it, and I doubt if I have even added a Qt over the whole time. if your going through that much oil, you need to find out where it is going. Out the exhaust, on the ground, Out the valve seals, around the rings. Once you know where it is leaking, then you have the chance to fix the problem.
Illegitimus non carburundum. Or something to that effect. Jack of all trades, master of none.
Diverrick is offline
post #4 of 30 (permalink) Old 09-05-2016, 02:33 AM
Spazz's Avatar
Need feed back.
I have the 120ST was was using around 1.5 qts per 1000 miles.... they took it down at 7300 miles and replaced the pistons, rings, jugs and rebuilt the heads since the valve guide seals were leaking as well.
What were the readings on the leakdown and compression checks? Sounds like they are avoiding it.... I doubt it has been torn down 5 times and nothing was found... unless you personally saw it torn apart each time... I would be very suspicious.
My jugs were scored, rings never seated and valves stems showed oil deposits and pistons were coated with wet/oily carbon.
Im showing you my teardown to let you see what can be seen when they tear it down.... you should have deposits like this on the pistons and valves at least, which means SOMETHING is wrong.
I have over 11K on it now... all is good
reds4 likes this.
RENO BAGGER AUDIO
Spazz is offline
post #5 of 30 (permalink) Old 09-05-2016, 03:01 AM
Almost 40k and not a drop.Even running across country, it never used a drop.
Big_gary is online now
post #6 of 30 (permalink) Old 09-05-2016, 06:20 AM
cookie114's Avatar
My 13 with 17k on it uses about 1 qt-1.5 qt in 4000 miles. Its uses mainly when riding on the freway at higher speeds. It wont hardly use a drop until then. Its been doing that since I got it in September 2015 with 5000 miles on it. I hate it but its just how tje cookie crumbled because its not enough usage to have anything done about it under ESP. This is the first out of six harleys I've had to use any.
2013 FLTRX, stage 1 w/vance and hine power duals and rinehart slipons, TTS mastertune and some other odds and ins. Long ways to go
cookie114 is offline
post #7 of 30 (permalink) Old 09-05-2016, 06:30 AM
RFG7680's Avatar
My 08 used 1 to 1.5qts every 2k. Did it from day 1 to 45k. My 11 used a qt every 1500ish. Only had that 11 months and put on 7k. My 16 with 6k has not used a drop in between the 2 services so far.
RFG7680 is online now
post #8 of 30 (permalink) Old 09-05-2016, 07:30 AM
mastergunnera8's Avatar
5 times? Dang, what year is it? Check the lemon law where you're at...my 2010 doesnt use anything between changes, 28K miles...
mastergunnera8 is offline
post #9 of 30 (permalink) Old 09-05-2016, 08:36 AM
staush's Avatar
Oil usage
My 2005 had 58k on it and my 2011 has 41k on it. They both used about 1/2 qt. between 5k oil changes.
staush is offline
post #10 of 30 (permalink) Old 09-05-2016, 10:28 AM
JacktheBagger's Avatar
Mine has over 50000 and uses very little , most of mine is blown out because of high speed interstate running , I added 12 ounces last week to bring it up to the middle of the hash marks and the oil has 6500 miles on it ....
2011 Ultra
JacktheBagger is offline
Spark Plug Usage Top Gun *General Road Glide Discussions/Pictures 16 09-24-2017 06:24 PM
RG Miles per year bagger51 *General Road Glide Discussions/Pictures 82 02-24-2015 11:19 AM
My 95's Oil Usage Mystery(sort of) hawk06Glide Engine Related 20 02-11-2015 12:54 PM
data usage and schmartt phones JacktheBagger GPS 14 01-28-2015 07:11 AM
PER Forum: TracyB Happy Birthday! FLTRXS20 *General Road Glide Discussions/Pictures 33 12-17-2010 01:16 AM
