2013 Road Glide trans dipstick - Road Glide Forums
post #1 of 5 (permalink) Old 09-08-2016, 08:54 PM Thread Starter
89FXRS's Avatar
a friend of mine has a factory shop manual for a 2009 Road Glide and it says do not screw in the dip stick when checking the trans fluid level, another friend has a factory shop manual for a 2012 Road Glide and it says to screw the dipstick in to check the trans level - I thought they would all pretty much be the same and was wondering why they are different - I'd like to know what procedure would be used to check the trans fluid on a 2013 Road Glide - thanks guys
If you're talking behind my back - then you're in a good place to kiss my ass!!!
89FXRS is offline
post #2 of 5 (permalink) Old 09-08-2016, 09:21 PM
I just happen to have my 13 manual and it says...
Page 1-25 section 1.10
3. Insert dipstick into transmission. thread dipstick in until O-Ring makes contact with case. DO NOT TIGHTEN.
4. See figure 1-12. Remove the dipstick. Check the lubricant level on the dipstick.
jethro_3 is offline
post #3 of 5 (permalink) Old 09-08-2016, 09:29 PM Thread Starter
89FXRS's Avatar
should it be checked on the kickstand or straight upright?
89FXRS is offline
post #4 of 5 (permalink) Old 09-08-2016, 09:33 PM
1. Park the motorcycle on a level surface leaning on the jiffy stand.
and 2 for good measure ... remove and wipe....
5. The level should be between the A and F marks. Add lubricant if necessary. Refer to table 1-10.
6. Install the dipstick. Tighten to 25 - 75 IN-lbs. Note that is INCH.
jethro_3 is offline
post #5 of 5 (permalink) Old 09-08-2016, 09:38 PM Thread Starter
89FXRS's Avatar
Thanks jethro_3
89FXRS is offline
HD Trans Dipstick Lundbeno Miscellaneous for Sale 0 04-02-2016 10:24 PM
Misc. Small Touring Parts..WS Gasket, Oil Dipstick, Amber Lenses Bigdaddymike Parts for Sale 0 11-10-2012 11:17 PM
Harley Digital Oil Level and Temp Dipstick NO RESERVE Timinfla2 Classifieds Archive (3 months old+) 0 04-29-2011 04:08 AM
Cool DipStick for Softails DreamRider General Off-Topic Discussions 3 01-04-2011 07:24 PM
Oil Level and Temperature Dipstick with Lighted LCD Readout - Chrome longrides Classifieds Archive (3 months old+) 2 11-19-2010 03:50 AM
