which Tranny lube? - Road Glide Forums
 12Likes
post #1 of 45 (permalink) Old 09-11-2016, 08:36 PM Thread Starter
Darreldanger's Avatar
which Tranny lube?
Yo Bro's what transmission lube are you using? I just changed mine out at about 10,000 miles and it looked really bad as in gray in color meaning metal. I know that is too many miles but for some reason I didn't think it was that many. Anyway I was and still am using the standby Harley Formula + trans and primary chaincase lube. any recommendations?
Darreldanger is offline
post #2 of 45 (permalink) Old 09-11-2016, 09:30 PM
skratch's Avatar
no, it isn't too many miles. Harley specs the oil change interval for transmission at 20k. my cvo has over 26,000 miles on it. I changed the transmission fluid once at the 1k service, and then again at 20k.
opinions differ on the 'best' lube to use. i'm of the opinion that it's a gearbox, so use gear oil. the first change I went with mobil1 75w-90. this last change, I went with supertech 75w-90. yes, Walmart oil. its made by citgo, and has received some very good used oil analyses over at bobistheoilguy.com. plus, you can't beat the price. full synthetic, less than $10. i'll run it until I change again at 40k. when I check it, it still has good color and viscosity.
BlueBagger12 likes this.
skratch is offline
post #3 of 45 (permalink) Old 09-11-2016, 09:35 PM
bosshogg123's Avatar
AMSOIL V-Twin Transmission Fluid in mine; working great so far
bosshogg123 is online now
post #4 of 45 (permalink) Old 09-11-2016, 09:40 PM
'05Train's Avatar
Don't sweat it. 20,000 mile intervals and I put in Mobil 1 at 1,000 miles. I don't worry about it.
smitty901 likes this.
'05Train is offline
post #5 of 45 (permalink) Old 09-12-2016, 12:01 AM
JacktheBagger's Avatar
I use redline's tranny oil most times , right now it has Lucas 75-90 , has had BelRay as well , I am anal about it and wont run it 20k , I change the primary with the motor and the trans every other oil change which usually means 12-15000 ..
I'm with skratch , it's gears , so use gear oil ..
jeff338wm likes this.
2011 Ultra
JacktheBagger is online now
post #6 of 45 (permalink) Old 09-12-2016, 06:45 AM
I used both Mobile 1 and Valvoline 75/90 and 75/140 full synthetic gear lube in my 08 since it was new and the trans has over 100K with no repairs done to it at all. I use the 75/140 more now that I am in Arizona but when I lived in a cooler climate the 75/90 seemed to work fine. Also the Valvoline cost less (around $12 qt @ Autozone) then the Mobil 1 and it works just as good.
post #7 of 45 (permalink) Old 09-25-2016, 09:40 AM
Pompey's Avatar
I use redline's heavy tranny oil, Mobile1 in the motor and Rev tech in the primary. makes it easy to identify any leaks
Pompey is offline
post #8 of 45 (permalink) Old 09-25-2016, 11:09 AM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
Red Line Heavy Shock Proof
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #9 of 45 (permalink) Old 09-25-2016, 11:37 AM
I use Redline Shock Proof & change all fluids every 5K.
JDisMe likes this.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #10 of 45 (permalink) Old 09-25-2016, 01:09 PM
SMOKENJOE's Avatar
I USE Lucas Oil Heavy Duty Gear Oil BECAUSE MOST OF MY RIDING IS IN HOT WEATHER AND MY BIKE RUNS HOTTER WITH 11:1 COMPRESSION
SMOKENJOE is offline
Tranny oil or gear lube Lugnutz Fluids and Lubricants 13 06-01-2017 11:19 AM
Amsoil 75w-110 Gear Lube w/3500mi. Nevadasun Engine Related 3 07-20-2013 08:39 AM
Primary lube wet or dry? jim_b *General Road Glide Discussions/Pictures 7 04-25-2012 10:02 PM
Lube??? RedDogNC Controls & Handlebars 8 03-01-2011 10:44 PM
Trans Lube Change Luscruz Troubleshooting for Road Glides 10 09-18-2010 07:08 PM
