Transmission fluid issue - Road Glide Forums
post #1 of 11 (permalink) Old 10-10-2016, 07:05 PM Thread Starter
2007 Road Glide no engine work. Drained transmission yesterday, not primary. Fluid was "red" in color. The HD specific transmission lube that matched the part number in my owners manual, purchased at dealer is more like motor oil, more of a golden color. Is this going to cause future issues with seals/gaskets? I am not original owner so this was not expected.
What's your opinion, should I drain the gold and try to find some red tranny fluid? Thanks in advance.......
Chico1960 is offline
post #2 of 11 (permalink) Old 10-10-2016, 07:10 PM
RGKen's Avatar
Previous owner probably put Redline tranny fluid in it and you are fine with what you have. Redline is a great fluid to use but no need to switch back to it until the next time you have to change it. If you so choose....
2018 FLTRXS
RGKen is online now
post #3 of 11 (permalink) Old 10-10-2016, 07:13 PM
+ Redline
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 11 (permalink) Old 10-11-2016, 10:57 AM Thread Starter
Thanks for the replies and info.
post #5 of 11 (permalink) Old 10-11-2016, 12:52 PM
Don't freak out if/when you change your primary if it's red too.
Least ya be able to see the fluid
level with a little tint
reds4 is offline
post #6 of 11 (permalink) Old 10-12-2016, 08:43 AM
HD recommended 20 w 50 syn 3 in the trans for that year model, the Red line is a much better trans fluid then the syn 3 is. I always used Mobil 1 or Valvoline 75 w 90 or 75 w 140 full synthetic gear oil in the trans on my 08.
Redfish Joe likes this.
post #7 of 11 (permalink) Old 10-12-2016, 08:58 AM
Redfish Joe's Avatar
I have to in all of mine.
SuperTrapp cans, decatted head pipe, Dobeck TFI, Andrews 48H cams, Rivera Taper Lite push rods, Crane lifters, SE Ventilator, Khrome Werks 2+2 bars, Progressive springs in the front.
Redfish Joe is offline
post #8 of 11 (permalink) Old 10-12-2016, 08:59 AM
Dragon Dude's Avatar
I was using Amsoil 75-140 and it was good oil but i could still hear the transmission rattle. Easy to go into neutral and shifted fine. I went ahead and replaced it with Redline v-twin transmission oil and it is a lot more quite than the Amsoil was, just passing on what i observed.
Dragon Dude is offline
post #9 of 11 (permalink) Old 10-19-2016, 04:59 PM
Redline antishock is the way to go, gets rid of the clunk when shifting.
beltfed is offline
post #10 of 11 (permalink) Old 10-19-2016, 06:07 PM
Sure Iam not the only gritty grease ground drainer oil smudgin slick dick on this site ~§ or knock on steady Eddies head, pound a tranny's bottom or even it's carved in soap that any spevific major Lubricants marketed to today's standards will fail your MC even in extreme conditions (not withstandin g inferior mechanical components)
use to swear by, defying the 'biker gods' Golden Spectro on previous RK, why? My bikes before '94, though a lot less milage (distance running) were ran with Flag oil or the cheapest to find.
Those bikes were know high wear, and that they did, quality lubes were just were just the fat on the bacon.
Not gonna Bragg bout proven milage owned from new '03 Flt & '05 Flh, but their longivity reveals with just plain ol of the shelves HD
Spit
Hum, need to patent 'touch screen bandaides'
reds4 is offline
Transmission fluid into primary Lima14 Engine Related 38 10-30-2018 11:47 AM
Transmission Fluid NavyRGSRider *General Road Glide Discussions/Pictures 9 04-15-2018 05:00 PM
Low transmission fluid in M8 2016CTRoadGlide Engine Related 14 06-22-2017 02:38 PM
Primary and transmission fluid question ? Road dawg Tech Area 14 06-22-2013 06:49 AM
DIY-Oil/Transmission Fluid change videos..... CRAIG2 Videos 2 05-13-2011 11:11 AM
