View Poll Results: How often do you perform a 3 hole fluid change? | |||
With each and every oil change at set frequency? |
26 | 27.08% |
Every other oil change? |
29 | 30.21% |
Follow the Moco service reccomendations |
41 | 42.71% |
Voters: 96. You may not vote on this poll |
Oil Service interval vs Primary and Trans Problems
Hello Folks,
I have an interesting question to pose here.
I have heard of several folks having primary, stator and trans issues and I am wondering if it has to do more with service intervals than with the actual components themselves.
I am initiating a poll to see how many people change all 3 holes at the same time on a regular basis vs following the moco's intervals for all 3 holes separately and if those service intervals have any affect on the components.
Definitely not scientific by any means just wondering out loud.
I can honestly say that my motor, trans and primary issues have been literally nonexistent, I do change all 3 holes each and every time I do a service.
Chime in, discuss, the beauty is there are no right or wrong answers, just a place to learn as usual.
What is your oil change frequency? 3000mi, 4000mi, 5000mi?
Sponsored Links | |||
I always go by the MoCo Book - They built it so I'll follow their recommends
On the newer scooter, it's more or less by the book. Some times it might get done a little early, and some times a little late.
Trans and primary on the 10's
Oil at less than 5000. Usually less as the winter oil never gets close to 5000 and most summers its more than 5 and less than 10k miles.
Mobile1 or Pure oil in the motor, Shockproof in the trans, and Formula+ in the primary.
Oil at 5000 ,trans and primary at 10000 heavy shockproof in trans ,cvo oil in primary,and engine but will go with Redline in all 3holes next change
Skickat från min iPhone med Tapatalk
I change all 3 @ 5k. I have gone a bit over on 2 occasions. The trip to SVIV and SWVII put me over 5k.
Oil every 5k
Trans and primary every 10k
While under warranty I try to use HD Syn3... but sometimes I'm to lazy to do my service and I take to my local small shop.
Also, even though it's expensive I try to have the dealer service it once a year doing a full check on her. Usually try to average 3 services a year minimum.
2016 RG, 103 HO.
OIF | OEF Combat Infantryman '05 | '07 | '09
Although it's good practice to check your fluid often, if my trans or primary is not clear at all, it gets changed.
2016 RG, 103 HO.
Our 03' FLTRI anni is within a wk of her 14th'
Adds down to 7,500 mi/yr
Change oil/filter @3-4k primary most every x (friction material)
Trans maybe 5x, only when tinched slightly
If I let the oil go >4k seems it down a 1/2 qt
No issues before or after tensioners @ 85k
All three holes every 5000 miles including the oil filter so far (knock on wood) 57000 miles no issues
Mako Fade Shark added Tour Pak with pass backrest-drivers backrest-pass floorboards-saddle bag guards
Originally Posted by SteadyEddie
View Post
I also like to always make it a hot change, have all the fluids warmed up really well when draining them and I like to leave them to drip for a while before replacing the plugs, new o-rings on each plug each service as well.
My motto is that service parts such as o-rings and oil are cheap, regular, preventative mtce to preserve. Currently using Redline products for all 3 holes and an additional 3 ounces of "Powerup" lubricant in the motor oil.
Calgaryglide
Thread Tools | |
Display Modes | |
Similar Threads | ||||
chrome parts,rocker boxes,dash,primary,side trans cover | pat123 | Parts for Sale | 5 | 09-09-2014 12:04 PM |
Fluid change interval | Tim Powell | Fluids and Lubricants | 17 | 07-19-2014 12:45 PM |
Service Interval print checklists | Scootin | Do-IT-Yourself | 7 | 08-25-2013 12:19 PM |
Oil Change interval | bfore | Do-IT-Yourself | 13 | 08-04-2013 07:22 PM |
Clutch Adjustment Interval | jimmyray11349 | Controls & Handlebars | 5 | 01-26-2013 11:44 AM |
Posting Rules | |
