Page 1 of 2 | 1 | 2 |
Wet vs Dry
Planning on changing my primary cover. I don't know the difference in Wet capacity and dry capacity for the refiled. I suppose the dry capacity it's when you open it up. Don't juge me!!! Thank's
2015 RGS, CV B52 amp, Kappa 62.11I, BT355 LL.
Sponsored Links | |||
If you just pull the plug and refill that would be the wet qty. If you remove the primary and clean all the oil out of everywhere that would be the dry qty. Not everything comes out when you just remove the plug. I'm sure someone will explain it better than me.
2013 Roadglide Custom - Candy Orange
Drago's Dragula True Duals, Thundermax Tuner
Daymaker LED Headlights, Supershox
Dry means you remove the primary not just the derby cover. Wet is what you use for your services. However it is a good idea to do a visual check of the level not just dump the measured amount of lube in. The 2011 does not have a HYD clutch so it is easier to see down inside. Red line is what you are looking to fill it to Bike straight up.
If you don't get the standard owner manual with it give me a yell I have one around here some where free to a good home. Totaled a 2011so book just laid around all this time.
Thank you gentlemen, for my 2015 wet=38oz and dry=45oz. So i guess i wil poured 45 oz.
Originally Posted by Arch73
View Post
Thank you gentlemen, for my 2015 wet=38oz and dry=45oz. So i guess i wil pour 45 oz.
Wet fill is 38 oz. (normal fluid change)
Dry fill is 45 oz. (when you have dry clutch plates and primary)
(for 2016 bikes it's 34 wet and 38 dry – according to owner's manual)
'18 FLTRX • '04 BAR HOPPER • '94 FLSTC • THE BEST BIKE ...is the one you're on!!!
Last edited by Little Wing; 03-20-2018 at 08:02 AM. Reason: originally cited 2016 specs for primary volume
Bike straight up.
Do what your service manual recommends what to put in. The 38 wet and 48 dry sounds like the correct amount but make sure. I believed HD changed the primary cover to a thinner cover ( the cover doesn't stick out as far) and the thinner cover would take less fluid. I can't recall what model year the thinner cover was put on.
2011 owners manual 38oz is your wet and 45oz dry page 166. However still use the picture to ensure you do not over filling it. If it does not drain fully and you add 38Oz it could be over full causing problems finding N
ect.
ect.
Originally Posted by ironmark
View Post
Follow Smitty's pic. That is what's in the service manual. It will come to about 35-38 on a 15. There's no guess work on the primary- as soon as you visually see it touch the bottom of the clutch plate, you're done!
Thread Tools | |
Display Modes | |
Similar Threads | ||||
WET vs "DRY" engine cooling | Torquey | *General Road Glide Discussions/Pictures | 11 | 08-29-2013 08:28 AM |
Primary lube wet or dry? | jim_b | *General Road Glide Discussions/Pictures | 7 | 04-25-2012 11:02 PM |
OMG !!! Did I not properly dry it ? | groupw | *General Road Glide Discussions/Pictures | 15 | 09-01-2011 07:52 PM |
Hutmo, hope you're keeping your powder dry! | Quicksand | General Off-Topic Discussions | 0 | 08-20-2011 10:22 PM |
Posting Rules | |
