Water Pump Failure and Repair / 2016 RGU (Lots of Pics) - Road Glide Forums
 41Likes
post #1 of 40 (permalink) Old 07-11-2018, 07:09 PM Thread Starter
As Beaver documented in THIS THREAD, the water/coolant pumps (part number 26600012) in the Rushmore's are prone to failure, and now have been listed as "obsolete" with no replacement in HDNet as of this writing. Only one place had one near me and it was about $433, but I could not see spending that for an "obsoleted" part that is known to fail. No one knew when a replacement would be made available. There is a Bosch pump that is almost identical, but the endcap is different in that the electrical connection comes out of the end were it would interfere with the engine guard and maybe the frame, the HD one comes off the side.
SO as I mentioned in that thread, on the way to work I saw the amber engine light and red temperature lights come on, I was in a place I could not safely stop, and by the time I got it stopped I saw this on the Power Vision, the coolant was ambient temp at ~60* but the engine was at 266*. Definitely no water flowing, and the fans were blowing cold when forced on by rolling the throttle.
I nursed it home, not allowing the engine to get above 240-250ish. That evening I pulled the cover off, then the plug off the pump, I tested for voltage at the connector, all was good:
I already knew of the limited availability of the pump, so I decide to tear into it...what did I have to loose?
The screws in the endcap are potted, so after digging that out they appeared to be Torx, but smaller than a #10 so that must be some oddball screw. So I decided to make them "slotted" screw with the Dremel tool and a thin cutoff wheel. Nothing to loose right?
When I got the cap off, I looked all around closely and wonder why the hell a water pump need to be this complicated, really? But anyway I saw what appeared to be a set of contacts that was not closed together like the other similar ones were, hmmmm, could it be this simple?
Continued in next post:
2016 Cosmic Blue Pearl RGU
2002 883R Sportster
Kennyd is online now
post #2 of 40 (permalink) Old 07-11-2018, 07:21 PM Thread Starter
So I soldered the connection back together, took it up to the bike, and the pump ran! Wow I just save over $400 and could ride again I took the pump back to the bench and for the heck of it soldered all the similar contacts, just in case!
After I final test, I started reassembly. HD used two of these stupid non-reusable "Crimp Clamps" as they are called in the tech manual between the thermostat and the pump. Luckily I had a small worm clamp in the parts bin to replace it with:
I got everything together, filled and bled the system per the manual:
Then finally went for a 20 mile test ride, all is well!
[IMGhttps://lh3.googleusercontent.com/Bhngdv0poaLwK39y8EsEtZP_8HOTXe7Iz7zm7zQDwxsNKqH8ej xm6pSEcC_AxLsXvMO7dKFyKysB-yXa6bTTXvVzi8Eimd9Vlo2DiW4YGAaNvtJn2FznfNwHYlxr0ZL QelhlrSV9AUgJGG5xqwP0R22KejaNFj3gIRVWfQBqtHeZFBmdI KG7AtvenbfJwhg8DIGgmY51DKW05XEZp30eNchdFN2LwZ4vksf j8FJ3Nf6qBwiNTHjIrWUpGkUKM8fbD1cYfqFKLyYozlnUZFXQI XzFD9MWnzL3NwwGS677lsV-gRevF_acn9RZpv2zPZcED9V4_PL1jwF-AzXS7CbQ0VCVgqqQI0j3AK9vu5RLI1gXfnjEU7M7ykOJ8rKKL-A12b0T8nQoG-p9p1WgppYFwX4ruP48FfYJRj19xZHTmROOcr2Zwn8pkBqPP-x1AfU_ag1mxJZA7uWjmKxd2p7op0r7bdUlLd0znCdX2okHWVgD ufYqhVchTeB2g99yDHGsBLLPatYL6hPjgR8GEK7SpogSTz7N2n RsNbmkhrWIqPcE4S8Tzt__JEem_7yHL0EQAn7c47o9m8hgKUBt upCtz_KlRahxK-yJvUJkcnrpApn42BB7kThGtcHP9_oRaTmfDSrMjatYjWUx7Cca hmIhc_v9IdN9P8oS=w1211-h909-no[/IMG]
I hope this helps someone else! If you have a dead pump that you don't want I'll pay the shipping to get it, or take it apart yourself and see if it's the same failure, I'd love to know!
KennyD
Wood, smitty901, Bruce00 and 8 others like this.
2002 883R Sportster
post #3 of 40 (permalink) Old 07-11-2018, 08:05 PM
PBSTN's Avatar
Proof once again. That some things are better done yourself. Funny thing is. Is that you did a better job of repairing it than the moco would have.
Kennyd likes this.
2001 FLHR-Traded. 2010 FLTRX-Sold.
2010 FLHR
2003 FLHRSEI2
PBSTN is offline
post #4 of 40 (permalink) Old 07-11-2018, 08:28 PM Thread Starter
For some reason (well I know what the reason is...that damned VS screwed up the forums) I can't get my edit to save so the last pic shows up. Here it is:
2002 883R Sportster
post #5 of 40 (permalink) Old 07-11-2018, 08:49 PM
That's awesome! I hope that if/when mine goes, it'll be that easy of a fix.
Has Harley really obsoleted this pump with no replacement? How can they actually do that and leave potentially thousands of bikes grounded?
Schulzy is offline
post #6 of 40 (permalink) Old 07-12-2018, 01:12 AM
Good job, pictures and explanation are clear on what to look for electrically.
Glad you fix it.
Kennyd likes this.
Beaver is offline
post #7 of 40 (permalink) Old 07-12-2018, 04:54 AM Thread Starter
Yes they have...just as I and Mr. Beaver wrote about in the thread I referenced.
2002 883R Sportster
post #8 of 40 (permalink) Old 07-12-2018, 06:52 AM
RonC26's Avatar
Congrats & thanks for the great repair post. Five stars! ⭐️⭐️⭐️⭐️⭐️
flhman and Kennyd like this.
A ship in harbor is safe, but thats not what ships are built for - John A Shedd
RonC26 is offline
post #9 of 40 (permalink) Old 07-12-2018, 07:31 AM
JacktheBagger's Avatar
Awesome , and I will sticky this one to keep it at the top ..
Kennyd and Beaver like this.
2011 Ultra
JacktheBagger is offline
post #10 of 40 (permalink) Old 07-12-2018, 09:08 AM Thread Starter
Wow, thanks Jack!
2002 883R Sportster
2015 / 2016 Road Glide Speaker Fitment Success and Failure wevsspot Audio 67 07-11-2019 11:31 AM
Water Pump obsolescence Beaver Fluids and Lubricants 50 04-23-2019 10:39 AM
Lost a cam bearing failure in a TC-88 Lots of questions Rusty Engine Related 25 10-07-2018 08:00 PM
2016 Road glide J&M Rokker Extreme failure Steven B Dickens Audio 1 07-12-2017 11:54 PM
Baker Tensioner install - with lots'o pics modot66 Engine Related 8 07-29-2013 10:51 AM
