Had to add a quart of 10w 40 in a pinch. - Road Glide Forums
 8Likes
post #1 of 13 (permalink) Old 09-03-2018, 03:49 PM Thread Starter
twincam103b's Avatar
I know bringing up anything to do with oil is not the best subject but I have to ask. While out on a ride today I decided to check my motor oil on my 2011 Road Glide Ultra. Sure enough it was down a quart. Finding oil for a Harley Davidson up here in my neck of the woods is not an easy thing to do. Today being a holiday it was worst. Anyway I find some Rotella t 15w40 full synthetic for big trucks and tractors so I dumped it in the motor. I am thinking Jesus it can't be the end of the world it's heavy duty synthetic oil.
Thoughts on this bad or not so dad idea. I rode for about three hours after this in some real heat. I didn't notice any strange noises in the motor.
Here are the specs:
API, CK-4, CJ-4, CI-4 PLUS, CI-4, CH-4; ACEA E9, JASO DH-2,
MA/MA 2; Caterpillar ECF-2, ECF-3; Cummins CES 20086; DDC
DFS 93K222; Deutz DQC III-10 LA; MACK EOS-4.5; MAN M3575;
Last edited by twincam103b; 09-03-2018 at 05:15 PM. Reason: My bad I just checked the oil it's 15w40 Rotella t not 10w40 Rotella t
twincam103b is offline
post #2 of 13 (permalink) Old 09-03-2018, 03:52 PM
masterblaster's Avatar
not a prob, you should be able to use that oil til the next scheduled change, now you gotta figure out why the bike is burning oil
nytryder likes this.
Hoka Hey Rider # 108
masterblaster is offline
post #3 of 13 (permalink) Old 09-03-2018, 04:19 PM
Check the label on the Rotella if you still have it...If you look, it should have a motorcycle rating on it. I forget the specific code...JA maybe? I ran Rotella full synthetic on my metric and it worked great. I think you'll be fine
Vertol is offline
post #4 of 13 (permalink) Old 09-03-2018, 04:57 PM Thread Starter
I have put 4000km on the bike since I got it from the dealership. I hadn't noticed it being down until today while out for a ride. I'm almost due for a oil change anyway so I will watch the oil closer for the next while. I'll be doing the next oil change myself and will monitor closely. Any ideas on what could cause the bike to burn oil... never experienced this with any other bike I have owned.
post #5 of 13 (permalink) Old 09-03-2018, 05:16 PM
dieselshadow's Avatar
If you ride with some “energy” or high speeds, you will use some oil. It’s the nature of the beast. However, if you haven’t changed and aren’t riding a bit more “spirited”, then you may have an issue.
eddienelson likes this.
2013 FLTRU
dieselshadow is offline
post #6 of 13 (permalink) Old 09-03-2018, 05:46 PM
a quart over 3k miles isn't the worst, just fill it with Mobil1/Amssoil or another good synthetic on the next service and monitor. you likely dont have an issue.
nytryder and ALMOONEY like this.
post #7 of 13 (permalink) Old 09-03-2018, 06:08 PM
RGKen's Avatar
You're thinking the MA/MA2 rating and the truck oil is not going to have that. It's not the end of the world though and he will be fine until his next service.
2018 FLTRXS
RGKen is offline
post #8 of 13 (permalink) Old 09-03-2018, 06:40 PM
Rotella carries the JASO and MA/MA 2 rating...You'll be fine
Vertol is offline
post #9 of 13 (permalink) Old 09-03-2018, 11:32 PM
JacktheBagger's Avatar
Whatever you do , do not read the owners manual for the '11 . It will tell you that if you have to add and can't find Harley oil to add a diesel oil , and dump it all and replace as soon as possible with Harley oil .
RGKen and Vertol like this.
2011 Ultra
JacktheBagger is offline
post #10 of 13 (permalink) Old 09-04-2018, 10:16 AM
jcarruth's Avatar
HD pisses me off with the oil and lube statements in the owners manuals. Greedy bullshit to sell oil that is probably rebranded Quaker State or whatever.
With a separate oil bath for the engine, you can run any oil you want, just be sure the viscosity ratings are close to 10w-50, depending on what temp you are operating in.
My ST1300 has a wet clutch shared oil bath with the engine, I have run Rotella 15w-40 in it for over 100k miles/14 years. I run it in all of my wet clutch Japanese bikes.
What you do not want to do is put any oil in a bike that shares the engine oil bath with the clutch basket that says "energy conserving" on the label. The same is true for the primary oil bath on our RGs.
2017 HD Road Glide Special
jcarruth is offline
Cold Start Issue - Won't turn over below 40 but starts fine when over 40 KRav7 *General Road Glide Discussions/Pictures 11 12-13-2016 11:31 PM
2012 take off parts chrome mirrors 40$ stock wind shield 30$ throttle cable 40$ front ccsolo24lal Parts for Sale 0 03-05-2015 04:56 PM
Ever hear of LIQUI MOLY 10w-60 100% synthetic? Mountainman Fluids and Lubricants 7 07-24-2014 09:17 AM
The dreaded Pinch is back!....0612's pfd161 Controls & Handlebars 4 09-03-2012 05:00 PM
Pinch Bolts on front wheel axle Teagatron3000 Tech Area 9 09-02-2012 06:54 PM
