for primary oil, i use shell rotella t 15w-40. can buy it almost anywhere, my local advance auto has it for about $15 for a gallon jug. enough to do almost 4 oil changes.
i change mine every 5k along with the engine, even though the manual specs 10k on the primary. when i had a cable clutch, i would do the primary change and adjust the clutch every engine oil change. kept the bike feeling 'new'.... now, with the hydraulic clutch, no adjustment, but still continue to change the primary oil every 5k to get all the crud out of there.
oh, and the rotella t is jaso rated for wet clutch use.
