Transmission Oil Smells weird - Page 2 - Road Glide Forums
 22Likes
post #11 of 20 (permalink) Old 05-05-2019, 07:49 PM Thread Starter
Skip Vargas's Avatar
Originally Posted by Nordic Berserker View Post
Makes me want to get one
2019 ROAD GLIDE SPECIAL
Stage 11 Torque Cam
Skip Vargas is offline
post #12 of 20 (permalink) Old 05-06-2019, 05:33 AM
geo8866's Avatar
Originally Posted by Skip Vargas View Post
2019 RGS at 1,500 miles with new motor at 500 miles on it. So I've been checking my fluids every ride and ride I pretty hard when i ride. But the trans oil has a funny smell to it and it looks clear as can be on the dip stick. All 3-holes have SYN3 recommended from MOCO tech do to the new motor. Maybe when they did the 1,000 mile service that had the break in oil and switched to SYN3 it puts out a different smell until the next oil change.
Am I reading this right? Your 19 bike has 1,500 miles on it but the engine only has 500 miles. Did you have to replace your engine already or am I reading this wrong?
Bruce00 likes this.
geo8866 is offline
post #13 of 20 (permalink) Old 05-06-2019, 05:36 AM
geo8866's Avatar
Originally Posted by Thermodyne View Post
It might not smell like the syn 3 left in the bottle, since it will be mixed with a little of the original gear oil.
Now here's the thing, syn 3 is not what the MoCo recommends for that gear box. If you look in the manuals they recommend Formula+, which is gear oil. syn three can pass the tests they rate gear oil under, but it con not have the additional high pressure additives such as zinc. I would would spend $10, drain the motor oil out and put gear oil back in. Either formula+ or synthetic gear oil from Wally's.
Thermodyne, Do you have an opinion on the new Harley 80/140 gear oil?
geo8866 is offline
post #14 of 20 (permalink) Old 05-06-2019, 06:56 AM
twowheeladdict's Avatar
I have 1000 miles on my Himalayan now. Seeing places I could never ever see on the Harley. You'd probably need a KTM or BMW for the larger rider triangle.
2018 Road Glide Special, 2018 Moto Guzzi V7III Carbon, 1975 KT250 Trials
twowheeladdict is offline
post #15 of 20 (permalink) Old 05-06-2019, 08:21 AM
Thermodyne's Avatar
Nope.
With that said, there's no reason you couldn't run synthetic 80/140 in a Harley trans. People have been running 80/140 in 5 speeds sice before there was synthetic.
geo8866 likes this.
Thermodyne is offline
post #16 of 20 (permalink) Old 05-06-2019, 08:24 AM
Thermodyne's Avatar
Sounds like I may have miss understood the tech, but i will call tomorrow and make sure. If he did use SYN3 then i will dump it and run gear oil for the gear box. Thank you for the info
The most profitable oil the MoCo sells is syn3. And by using one oil, there is only one partial bottle left over, instead of two.
Also, the MoCo schools up techs on the virtues of syn3, basically the same stuff you see in oil ads. And while it is arguable better for the engine, the same does not hold true for the other holes.
post #17 of 20 (permalink) Old 05-06-2019, 10:04 AM
I am also interested in what happened. Hope to hear about this.
beerhunter is offline
post #18 of 20 (permalink) Old 05-06-2019, 06:35 PM Thread Starter
Yes you read it correctly.
My motor had noises and it started at about 40-miles on the bike, brought to the dealer and they said put more miles on it. I then started recording the noises and mileage and emailed it to the dealer who then sent it to moco with a reference number.
After i had enough and dropped my bike off with 900 miles on it and demanded they fix it or give me another bike on the floor. From there moco wanted my ECM down load and to tear the cam chest open, then the dealer found a lifter bore scored. Then moco wanted a top end tear down after they scoped it and found some scratches on the rear cylinder they flew out a tech specialist.
Now i have 650 miles on the new motor
Within 24hrs the tech specialist expedited a new complete motor with a new stage 2 cam kit and they threw in the 1,000 service... I have to say that the dealer and moco really took care of this issue, so as long as you don't put an aftermarket tuner on your bike you won't have any issues with factory warranty
Bruce00 and geo8866 like this.
Stage 11 Torque Cam
post #19 of 20 (permalink) Old 05-06-2019, 06:41 PM Thread Starter
You are right about that, called the dealer and they did use the Formula+ in the gear box.. Thank you, man it has a very lite odor but i couldn't call it
Stage 11 Torque Cam
post #20 of 20 (permalink) Old 05-06-2019, 08:22 PM
Bruce00's Avatar
Sorry for all your issues, but glad to hear they took care of you.
I also read your first post and was scratching my head, I just figured it would come out
Wishing you the best of luck in your future miles
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
M8 low transmission fluid ameleo Fluids and Lubricants 11 01-16-2019 03:22 PM
2010 Road Glide Transmission Bearing Rob-B Do-IT-Yourself 1 11-12-2018 06:47 PM
Broke another transmission. I suck gbourdon Engine Related 9 09-15-2014 02:06 PM
Transmission - Rebuild? Replace? gbourdon Engine Related 19 08-08-2014 07:25 AM
Transmission problem vontoughguy Troubleshooting for Road Glides 4 08-19-2010 04:30 PM
