Transmission Oil Smells weird - Road Glide Forums
 22Likes
post #1 of 20 (permalink) Old 05-05-2019, 09:21 AM Thread Starter
Skip Vargas's Avatar
2019 RGS at 1,500 miles with new motor at 500 miles on it. So I've been checking my fluids every ride and ride I pretty hard when i ride. But the trans oil has a funny smell to it and it looks clear as can be on the dip stick. All 3-holes have SYN3 recommended from MOCO tech do to the new motor. Maybe when they did the 1,000 mile service that had the break in oil and switched to SYN3 it puts out a different smell until the next oil change.
2019 ROAD GLIDE SPECIAL
Stage 11 Torque Cam
Skip Vargas is offline
post #2 of 20 (permalink) Old 05-05-2019, 09:26 AM
dieselshadow's Avatar
There are lots of things to sniff out there, I wouldn't be picking my trans oil to be at the top of the list. There's all kinds of recreational sniff stuff available.... LOL
Does it smell like sulpher? Gear oils tend to smell like rotten eggs, at least a bit. If that's the case, you're fine. They certainly didn't use Syn3.
Skip Vargas likes this.
2013 FLTRU
dieselshadow is online now
post #3 of 20 (permalink) Old 05-05-2019, 09:36 AM Thread Starter
I think you hit the nail right on the head.. I was gonna say it smelled like a lite hint of
curry,but didn't want to offend anyone.. The tech told me they ran all 3-holes with SYN3 and he gave me a half of quart left over.
Stage 11 Torque Cam
post #4 of 20 (permalink) Old 05-05-2019, 12:00 PM
Thermodyne's Avatar
It might not smell like the syn 3 left in the bottle, since it will be mixed with a little of the original gear oil.
Now here's the thing, syn 3 is not what the MoCo recommends for that gear box. If you look in the manuals they recommend Formula+, which is gear oil. syn three can pass the tests they rate gear oil under, but it con not have the additional high pressure additives such as zinc. I would would spend $10, drain the motor oil out and put gear oil back in. Either formula+ or synthetic gear oil from Wally's.
Thermodyne is online now
post #5 of 20 (permalink) Old 05-05-2019, 12:23 PM
Desert Rider AZ's Avatar
Curry? LOL. That sounds more like the Royal Enfields lol
FLTRXS18 and Skip Vargas like this.
Desert Rider AZ is online now
post #6 of 20 (permalink) Old 05-05-2019, 02:34 PM
twowheeladdict's Avatar
Since 1901! Curry and Crumpets!
2018 Road Glide Special, 2018 Moto Guzzi V7III Carbon, 1975 KT250 Trials
twowheeladdict is offline
post #7 of 20 (permalink) Old 05-05-2019, 03:40 PM
Nordic Berserker's Avatar
Makes me want to get one
Nordic Berserker is offline
post #8 of 20 (permalink) Old 05-05-2019, 03:52 PM
And I am told that you do not want to mix syn3 and formula+.
I blieve they come the factory with formula.
beerhunter is offline
post #9 of 20 (permalink) Old 05-05-2019, 05:24 PM
Thermodyne's Avatar
They come with Formula+. but it may have something added to it as far as break in goes. I've seen a lot of 1000 mile service oil reports that show copper in the trans oil, and there is no yellow metal in the trans that I know of. But copper sphericals are popular for breaking in anything that uses oil as lube, and does not have a cat down stream.
post #10 of 20 (permalink) Old 05-05-2019, 07:48 PM Thread Starter
Sounds like I may have miss understood the tech, but i will call tomorrow and make sure. If he did use SYN3 then i will dump it and run gear oil for the gear box. Thank you for the info
Stage 11 Torque Cam
M8 low transmission fluid ameleo Fluids and Lubricants 11 01-16-2019 03:22 PM
2010 Road Glide Transmission Bearing Rob-B Do-IT-Yourself 1 11-12-2018 06:47 PM
Broke another transmission. I suck gbourdon Engine Related 9 09-15-2014 02:06 PM
Transmission - Rebuild? Replace? gbourdon Engine Related 19 08-08-2014 07:25 AM
Transmission problem vontoughguy Troubleshooting for Road Glides 4 08-19-2010 04:30 PM
