Removed the "Do not remove" Plug - Road Glide Forums
 32Likes
post #1 of 21 (permalink) Old 07-06-2019, 01:49 PM Thread Starter
Question Removed the "Do not remove" Plug
I did my first 3 hole oil change on my (new to me) 2015RGS in the Fall after watching Ryan Urlacher's YouTube video with no issues. I just took the bike for a nice long ride and came back to drain the hot fluids and removed 4 bolts, not 3. The picture attached shows the 4th plug I wasn't supposed to remove (#3 labeled Hex Plug (do not remove) from the Service Manual...uggh... I realized something wasn't right when it had red thread lock on it after I took it out. Question - How bad did I screw up and will the fluid that came out of that hole be replaced when I fill the 3 holes? I'm hoping someone here knows what that plug drains...Thanks in advance for your help and advice!
Stress less...Glide more...
splante is offline
post #2 of 21 (permalink) Old 07-06-2019, 02:22 PM
Thermodyne's Avatar
Clean it up and put it back with some red loctite.
On my 11, I use that hole for the oil temperature sender.
Thermodyne is offline
post #3 of 21 (permalink) Old 07-06-2019, 02:32 PM Thread Starter
Thanks Thermodyne!!
Jacksprat56 likes this.
splante is offline
post #4 of 21 (permalink) Old 07-06-2019, 03:23 PM
RFG7680's Avatar
Yep. My buddy did it. Shove it back in. It's fine.
splante likes this.
RFG7680 is offline
post #5 of 21 (permalink) Old 07-06-2019, 04:03 PM
smitty901's Avatar
Don't over tighten it or it could cause a problem. Do as others said and then leave it alone.
splante likes this.
smitty901 is offline
post #6 of 21 (permalink) Old 07-06-2019, 04:07 PM
Bleachey's Avatar
Sounds like a lawsuit since it wasn't clearly marked to me...................
splante likes this.
2011 Road Glide Ultra
2002 Heritage Softail
l
Bleachey is offline
post #7 of 21 (permalink) Old 07-06-2019, 04:50 PM
skratch's Avatar
yep, it's a tapered pipe plug. overtighten it and you'll have worse problems.
i believe in the manual they refer to them as crankcase pipe plugs and have a torque spec of 120 INCH/lbs.
splante likes this.
skratch is offline
post #8 of 21 (permalink) Old 07-06-2019, 05:01 PM
RGKen's Avatar
Holy crap! That was a big mistake! Hurry up and put it back in and take it straight to the dealership and trade it in before the engine blows up!
1st Sgt, snarley53, GMONEY and 5 others like this.
2018 FLTRXS
RGKen is offline
post #9 of 21 (permalink) Old 07-06-2019, 05:18 PM
BH#103's Avatar
I think when you remove it there is a notification sent that your power train warranty is voided!
RGKen, Taz_FL, wevsspot and 4 others like this.
"SLIVER"
BH#103 is online now
post #10 of 21 (permalink) Old 07-06-2019, 05:19 PM
If it was me, I'd overtighten it, crack the oil pan and have a excuse to buy the deep pan.
immo2896 and splante like this.
Buzzy is offline
