Experience with Royal Purple? - Road Glide Forums
post #1 of 17 (permalink) Old 09-20-2013, 07:47 AM Thread Starter
I ran Royal Purple in my 2001 sportster for years and years without issue.
When I first switched over, I switched from Amsoil. The Amsoil ran great but I was still not to happy. The temperature drop from Harley dinosaur oil to Amsoil was about 15 C, The drop from Harley to Royal purple was 20+ C on a hot day.
I'm looking to swap my 2011 glide over from Dino juice to Royal Purple on my next change. Whats everyone elses experience on a big twin with RP?
Randomglide is offline
post #2 of 17 (permalink) Old 09-20-2013, 07:57 AM
smitty901's Avatar
RP is a high quality. product US owned company and US made product.
It is every bit as good as any other high end SYN oil and lube
smitty901 is offline
post #3 of 17 (permalink) Old 09-21-2013, 05:01 PM
bronxbill's Avatar
Royal Purple is a good high end synthetic oil and will work great. Oil choice is very subjective and you will get a ton of different suggestions
2013 Roadglide Ultra Midnight Pearl, Vied's, Mach2 Air Cleaner, Screamin' Eagle Slip Ons, LRS 13' Mako Windshield, Edge Cut Billet Saddlebag Latches, CVO Mirrors, Black Heritage Style Bars with Edge Cut Levers, Chromedome Horn Cover, Mean Mug Bezel, Pinstiping by Wild Bill
bronxbill is offline
post #4 of 17 (permalink) Old 09-21-2013, 05:38 PM
I've used RP with good results, it's just getting more expensive and harder to find.
post #5 of 17 (permalink) Old 09-22-2013, 07:13 AM
Bigtrev8xl's Avatar
And I've always put Harley oil in my bikes without issue.
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #6 of 17 (permalink) Old 09-22-2013, 07:23 AM
BlackBetty11's Avatar
lol... I did too until getting back over here... the temps in Europe didn't need any other oil. But when your day starts every day anywhere above 26ĚC you do look at other options.
2011 FLTRU103Cali
2006 XL1200C
If only my job would understand that I have other things to do!!!
H.O.G. First International Free Chapter
Green Knights Chapter 27
BlackBetty11 is offline
post #7 of 17 (permalink) Old 09-22-2013, 09:00 AM
sj01fltri's Avatar
I ran RP in my 01 RG for more than 60,000 with a 95 inch motor with out an issue it just got too pricey,so now using Lucas so far so good
sj01fltri is offline
post #8 of 17 (permalink) Old 09-22-2013, 10:46 AM
911Shark's Avatar
RP works great. My 103 temp dropped about 10 degrees over HD Syn
2015 CVO/SEPRT/Arlen Ness Big AC/NO Cats/nada mas
2004 SE 103"/Branch P&P heads/Branch 595 Cams/Diamond Cut/SE 6speed/SERT/2n1 Ceramic ThunderHeader/Progressive Monotube F, 444 R
911Shark is offline
post #9 of 17 (permalink) Old 09-22-2013, 10:57 AM
mitchdm's Avatar
I ran royal purple in my 10 (73k when sold) and my 06 (93 k when traded), no issues ~ on the 12 the motor builder highly recommended I use a blend or Dino ~ I am ordering Brad Penn 20/50 motorcycle by the case on Amazon. Cheaper than RP ~ but time will tell on the motor. ~ 17k since my build figure I'll be a a hundred k on the build in two years.
I am a RP fan but will use what the builder recommended for now.
mitchdm is offline
post #10 of 17 (permalink) Old 09-22-2013, 10:33 PM
I've been using RP since 2004 and never had an issue with it. I would highly recommend it.
Trooper is offline
Tags
amsoil , dinosaur , oil , royal purple
Royal Purple lubricant Thuval Fluids and Lubricants 1 06-17-2014 10:17 PM
Drone Medal out ranks Purple Heart WTF! L-Premo General Off-Topic Discussions 16 02-16-2013 12:12 AM
Royal Purple in Primary case Big Moke *General Road Glide Discussions/Pictures 3 09-27-2011 04:57 PM
Royal Purple Oil (input Please) Frodoe *General Road Glide Discussions/Pictures 4 07-22-2011 09:24 AM
Royal Purple ?????? Frodoe Engine Related 15 07-21-2010 11:42 PM
