GM Dexron 6 in Primary - Road Glide Forums
post #1 of 16 (permalink) Old 10-01-2013, 01:13 PM Thread Starter
equandt's Avatar
I have a quart of GM Dexron 6 ATF sitting on my shelf. Can it be used in the primary?
2012 FLTRX
2010 FLHTCU
equandt is offline
post #2 of 16 (permalink) Old 10-01-2013, 01:39 PM
PGR
PGR's Avatar
Do you have an extra 6 oz of it? Primary takes 38ish oz
Ron..........................
PGR is offline
post #3 of 16 (permalink) Old 10-01-2013, 02:52 PM
JacktheBagger's Avatar
I always run a quart , never any issues , and as PGR says , yes it's OK
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 16 (permalink) Old 10-01-2013, 03:18 PM
PGR
PGR's Avatar
JtB
That's why I said 38ish
If you just drain and then refill, a quart is about right. But if you do an extended, several hour drain, and work the clutch, by holding it open with a zip tie, you can get several oz more out of the clutch plates.
I have a lever lift, similar to the one pictured below. I put it under the frame at the front, and lift the bike, and let it drain for at least a couple of cold beers. It's surprising how much more primary oil comes out, by lifting the front and opening the clutch plates.
PGR is offline
post #5 of 16 (permalink) Old 10-01-2013, 03:54 PM
Torquey's Avatar
Very interesting about draining the primary oil out. I will do that next time around. I'm even a Rogue Chopper Scavenger oil purge guy.
Torquey is offline
post #6 of 16 (permalink) Old 10-01-2013, 07:12 PM
2010 FLTRX's Avatar
I don't think I'd run Dex6 in there. That's just synthetic ATF. It's quite a bit lighter than the promary needs and many ATFs have friction modifiers in them which isn't good for your clutch. Just my 2 cents.
Sal - 2010 Vivid Black FLTRX
2010 FLTRX is offline
post #7 of 16 (permalink) Old 01-10-2014, 11:26 PM
most automatic trans fluids have a viscosity of about 0W20 which is much thinner than what is recommended. as already mentioned, the friction modifiers will cause your clutch to slip and you will soon wear it out.
a friend of mine did this for some reason a couple of years ago before a week long trip we did along the blue ridge parkway, through the smoky mountains and the dragon etc, and the heat radiating from the primary after riding all the hills with the clutch slipping was ridiculous. he ended up burning the clutch out completely and all the seals in the primary ended up leaking, i assume they were also damaged from the heat. sounds a bit much, but it's what happened, i saw it.
wicked world is offline
post #8 of 16 (permalink) Old 01-10-2014, 11:31 PM
torqu's Avatar
Just get a Primary oil. I still don't understand why people put the synthetic oils inwhere there are clutches.
torqu is offline
post #9 of 16 (permalink) Old 01-11-2014, 03:49 AM
4getNo1's Avatar
Some ancient history here so take it for what it's worth...
Back when I was serious in drag racing and Bonneville, virtually ALL of us that used a closed primary also used ATF. Type "F" (Ford) had additives that dramatically reduced clutch slippage.
BTW - this also included all of our street scoots too. A real "healthy" engine sure could overcome the grip a stock clutch offers.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #10 of 16 (permalink) Old 01-11-2014, 09:08 AM
What's wrong with HD Formula+?? I don't get why guys want to use something sitting on there garage shelf that's not made for your bike? Spend a few bucks & purchase the proper oil. I do run Redline 20/50 & Redline Shockproof but run HD Formula+ in primary. Good luck.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
primary cover black-glide Troubleshooting for Road Glides 2 01-17-2011 07:15 PM
Primary locking bar? JefFLH Engine Related 5 11-16-2010 05:20 PM
Inner primary seal vinchenz07 Troubleshooting for Road Glides 5 04-30-2010 10:00 PM
