leaking brake fluid - Road Glide Forums
post #1 of 17 (permalink) Old 10-14-2013, 10:16 PM Thread Starter
leaking brake fluid
front master is leaking. cap has never been off. tightened screws. didnt over tighten gasket isnt squashed. still leaking. Could it be bad gasket ?also if i replace gasket do i have to bleed system ?
THEMASTERDESTROYER is offline
post #2 of 17 (permalink) Old 10-14-2013, 11:35 PM
They all will leak eventually regardless of being off or not. Also you dont have to bleed if you take the cap off just dont hit the lever. If im not mistaken i think the MoCo has a newly designed gasket and or cap because of them leaking
post #3 of 17 (permalink) Old 10-15-2013, 05:39 PM
fugly1's Avatar
I had the same problem on my 2012 RGC, bought the new "redesigned" gasket and problem solved ...just a couple of bucks at the local stealer.
fugly1 is offline
post #4 of 17 (permalink) Old 10-15-2013, 06:06 PM
You'll know if you suck air into it, still don't want that fluid @ controls
reds4 is offline
post #5 of 17 (permalink) Old 10-15-2013, 06:13 PM
Mine leaked too. Like said earlier, they make a new gasket and lid. This solves problem.
No bleeding necessary. Just get the master cylinder as level as possible before removing lid.
Big_gary is online now
post #6 of 17 (permalink) Old 10-16-2013, 10:43 AM
mllgator's Avatar
And DO NOT get fluid on any painted parts!!!
mllgator is offline
post #7 of 17 (permalink) Old 10-16-2013, 12:00 PM
I never had a issue with my 08 having a leaking master cylinder in the front or back. What year models did this problem start?
post #8 of 17 (permalink) Old 10-16-2013, 12:02 PM
Paul's Road Glide's Avatar
My 2012 leaked and I took it in and warranty covered it.
Paul's Road Glide is offline
post #9 of 17 (permalink) Old 10-16-2013, 04:59 PM
zemo1017's Avatar
New gasket/cap is the way to go if the leak is around the top. Mine leaked around where the line ties into the line. Deer strike bent something so the dealer replaced the entire master cylinder. It was good right after the collision but failed on the way to. Get a damage appraisal. Nothing like grabbing a handful of brake and nothing happens. Always use both anyway to start a stop so it wasn't a panic situation.
zemo1017 is offline
post #10 of 17 (permalink) Old 10-16-2013, 07:42 PM
I am having the same issue on my 2011 RGC, anyone have the new part # for the cap and gasket? Thanks
LM1976 is offline
Master Brake Leaking GSAHR Controls & Handlebars 10 05-26-2016 09:52 PM
Leaking brake reservoir after bar change faponce88 Controls & Handlebars 3 03-20-2016 01:59 PM
Primary fluid leaking at derby cover Shemp Troubleshooting for Road Glides 10 06-25-2015 12:14 AM
Brake Fluid Leak lldsilver41 Tech Area 2 09-10-2012 03:28 PM
How often do you flush your brake fluid? jcanrun *General Road Glide Discussions/Pictures 12 05-08-2011 02:28 PM
