Oil in Air filter - Road Glide Forums
post #1 of 12 (permalink) Old 11-05-2013, 11:52 PM Thread Starter
07Roadie's Avatar
Oil in Air filter
Been happening since two years ago when local HD changed my oil. However last year I had to put on an add-a-trike so I could ride it during my chemo treatments. My extended warrenty ran out so now I am planning on doing the next oil change myself.
I have an arlen ness big air kit on it and am wondering if maybe a dirty filter could be causing it to draw oil into the carb and farther into the filter.
On a second note, the book says check the oil while on the kickstand, I can't put it on the kickstand because of the trike kit, so how can I guess how much oil I need?
Thanks for any help.... I want to change the fluids before I sell it, but don't want to have to take it to dealer to service it.
07' HD Road Glide-with training wheels (Tow-pac trike kit),04' Suzuki 650 savage (thumper), 13' Kawasaki 300 Ninja
07Roadie is offline
post #2 of 12 (permalink) Old 11-06-2013, 03:18 AM
07Roadie, it is normal to have oil in the air filter, to meet EPA standards, Harley vents the crankcase pressure to the air filter so the suspended oil will get sucked into the combustion chamber and burned instead of venting to outside air. You should have two graduations on the oil dipstick one for on the jiffy stand and one with the bike level, so you can accurately check the oil with the bike in either attitude. I personally do not fill past the halfway mark on the dipstick, this helps with the oil build up in the air filter area. To clarify the crankcase builds up pressure due to the pumping motion from the pistons, at the same time oil is being sloshed around in the same area and being whipped around by the crank and rods, which some gets turned into vapor droplets, at the same same time the intake is creating a vacuum which aids in bringing the crankcase pressure up to the intake to be mixed with the incoming air and then sent to the combustion chamber and burned. All combustion engines use this design or very close to the same design to eliminate crankcase pressure. Sorry for the long post!
Glen66 is offline
post #3 of 12 (permalink) Old 11-06-2013, 03:26 AM
Sorry 07Roadie to answer you main question, the oil droplets that are being drawn from the crankcase is what you are seeing in your air filter. The hoses that are on the back side of your air filter are ported to the crankcase to bleed off the pressure. If you fill your oil level to the full mark you will have oil build up on the filter and filter area, like I said this is normal, if you fill slightly less than the full mark but higher than half way on the dipstick this will reduce the amount of oil in the filter area. Sorry again for the 2 part post, I promise to quit after this, lol
Glen66 is offline
post #4 of 12 (permalink) Old 11-07-2013, 09:25 PM Thread Starter
07Roadie's Avatar
Thanks, thought it was a dirty filter, was going to order a "back to original" air filter kit. My worries were I guess unfounded then, thanks tons.
07Roadie is offline
post #5 of 12 (permalink) Old 11-08-2013, 02:46 AM
07Roadie, look at post Leaking Oil Problem in this thread, the problem you are having, or lack of, is discussed pretty clearly in this post. Glad I was able to help.
Glen66 is offline
post #6 of 12 (permalink) Old 11-08-2013, 08:37 AM
Scoop's Avatar
Glen66, your post should be made into a Sticky! Its by far the best explanation of the oil breather operation I have seen so far.
I'm Just Sayin'!
Scoop
2011 FLTRU Fullsac Sportpipe, SE Breather/air cleaner, SEPRT Smart-tune, Corbin, Madstad 13", Gold Top Fork Emulators & Springs & JRI B shocks. 2003 XLHS
Scoop is offline
post #7 of 12 (permalink) Old 11-11-2013, 11:30 AM
Thanks Glenn66. I just filled my 2006 up to the Full Line. I think I will drain off a little to avoid the nuisance of oil in the air filter. Good info.
grambo is offline
post #8 of 12 (permalink) Old 11-11-2013, 01:31 PM
On the 2007 and later RG there are no rubber hoses for the crankcase vent that are in the back of the air cleaner housing. The crankcase vents through the top mounting bolts on the air cleaner housing. The top mounting bolts are hollow and the crankcase vents through the hollow bolts directly into the air cleaner. The oil in the air filter is a direct result of the engine being overfilled with oil, even though the manual say that the engine oil capacity is 4 qts of oil you should only add 3 1/2 qts when doing a oil change because when doing a oil change not all of the oil drains from the engine. If you are not sure of the dipstick reading the best way to make sure the correct amount of oil is in the engine is to only add 3 1/2 qts of oil when doing a oil change then read the dipstick.
post #9 of 12 (permalink) Old 11-11-2013, 09:36 PM
Jay2Beers's Avatar
Yep = "Blow-by"',... Drop the fill line down and yes this should be A sticky.
'13 Blk RGC crs/abs/sec 103 Stg2 255cam-plus D&D Boss Fatcat SE Super Tuner. Klockwerks 12", Blk 10"Chubby w/Blk Get-A-Grips. Skunked Day Maker. CD GEN2001157Amber/Wht Front & Red Rear Smoke Lens w/Magic Strobe & bits more, Always a WIP
Jay2Beers is offline
post #10 of 12 (permalink) Old 11-12-2013, 07:23 PM
gja
Lets take this a step further. How long until the oil stops dripping from the breather? I overfilled (yup stupid me) and kept wiping up. Got tired of cleaning up and changed the oil, filled with 3.5 qts. I still have oil blow by.
Does it take a while for the residual oil in the breather tubes to "empty"?
2012 BBP FLTRX
2009 FLHRC ( work in progress)
gja is offline
K&N Filter vs.HD Oil Filter RRHartzler Fluids and Lubricants 49 10-22-2016 07:00 PM
Removing oil filter with oil cooler 02heritage *General Road Glide Discussions/Pictures 17 05-11-2014 11:10 PM
oil smell & oil in air filter fat boy ultra Troubleshooting for Road Glides 6 04-11-2013 10:04 AM
Oil in Air Filter....the Cause?? Nevadasun *General Road Glide Discussions/Pictures 2 11-02-2011 06:08 PM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 11:38 AM
