Replacement for SE 260 cams? - Road Glide Forums
Forum rules! READ! These are the current forum RULES. Please Read!
 3Likes
post #1 of 18 (permalink) Old 05-27-2017, 10:26 PM Thread Starter
I just acquired a 2010 RG Custom - Stage 4 done in 2010 - package done with SE 260 cams. They don't really kick in until about 3000 RPM. Looking to replace over the upcoming winter with a cam that is more torquey at lower RPM's and better suited for putting around town (looking for the torque at the start vs the HP at the end of the powerband). This is going to potentially open the flood gates with options, but looking for ideas on a replacement setup. Any options that allow me to use the SE Tuner as well? Back of the napkin says its about $1000 to get a different SE cam (about $350), adjustable push-rods ($175), and the labor to install and re-tune ($400-$450). Any lower dollar thoughts greatly appreciated as well. And an explanation on the adjustable push-rods need would be awesome. I have the Freedom Performance tuck and under true duals and the Combat slipons (just switched out of the V&H 2-1 Pro Pipe)...not looking to maximize torque or HP - just want something a little more friendly in the 1500-3000 RPM range.
Captain America is offline
post #2 of 18 (permalink) Old 05-28-2017, 05:54 AM
HellInABucket's Avatar
Personally I wouldn't go with a Harley cam. There's also no such thing as cams that aren't "compatible" with the SE tuner, so you fine there.
As far as budget, they are all roughly the same, with all the other parts its not a huge range.
More details about your build would be helpful (displacement, compression, etc), but I would call a reputable builder - Fuel Moto, Hillside, Doc's Performance, etc, they would have good recommendations.
Short Time likes this.
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #3 of 18 (permalink) Old 05-28-2017, 09:08 PM Thread Starter
Thanks much
post #4 of 18 (permalink) Old 05-29-2017, 08:28 AM
There are many cam options that would work for you. I would suggest doing some research on cams, there are many web sites that have dyno sheets on different cams in different builds, Fuel Moto has a good dyno sheet section on Woods cams and you should check that out. I used a Woods TW222 and it was a great low/mid range torque cam, You can also consider a Woods TW555 or a Tman Troquester555. By checking the dyno sheets you can see where the torque curve starts and stops and then you can look up the cam specs. I look for cams that produce 100 ft lbs of torque around 2200 and 2500 rpm and it won't drop below 100 ft lbs of torque until 5000 to 5500 rpm.
VikingRider likes this.
post #5 of 18 (permalink) Old 05-29-2017, 12:11 PM
You might consider the SE 259s they come in sooner, still run out well on top...
'Ran the 259s for >11k mi. I liked them...
'Can sometimes $core the 259s (new) from folks that have bought SE Kits / Motors (with 259s) and change Cams during their Build...
Or if you want all "bottom" the SE 255s work well for a lot of folks,,, Sometimes $core (lo mile takeouts) from the CVO crowd...
'Have >160k miles (3 Bikes) on SE Adjustable Pushrods,,, Never any / or related issues...
True Duals by nature are usually a little "softer" on the bottom... 1.75 Baffles in the Mufflers help the TQ come in sooner...
Cdan19 likes this.
HeatWave is offline
post #6 of 18 (permalink) Old 05-29-2017, 03:02 PM
Road dawg's Avatar
Well if your glide has a 96 inch motor you wont find a cam that comes in sooner or produces plenty of low end and designed specifically for 88 and 96 inch motor than a Feuling 525 cam, i have them and the reviews are awesome as well as performance. They kick in at 1750 rpm all the way up to 5200 rpm smooth and linear torque all the way up no deadspots, i also used HD quickie pushrods and replaced my lifters with S&S premiums.
Road dawg is offline
post #7 of 18 (permalink) Old 05-29-2017, 08:53 PM
Chart please.
2018 FLTRU
post #8 of 18 (permalink) Old 06-02-2017, 10:34 PM Thread Starter
Dyno chart attached
See attached - graphs show the big hiccups at about 3000....
post #9 of 18 (permalink) Old 06-03-2017, 05:21 AM
I dont see any attachment.
2018 FLTRU
post #10 of 18 (permalink) Old 06-04-2017, 03:53 PM
Road dawg's Avatar
If you look on Feulings website they have it posted, going to try to get a copy and post it up, take a close look at it, smooth all the way up, i swear by these cams on a 88 inch or 96 inch motor.
Tags
cams , se 260 , stage 4
Installed of SE 254 cams & other SE parts Hillglide Engine Related 2 04-23-2017 11:52 AM
260 mile road trip todayht Diverrick Road Trip Discussions/Stories/Pictures 1 05-21-2016 09:38 PM
SE-255 Cams, SE Head Pipe, RCX Slipons ldireprophil Parts for Sale 11 06-17-2013 10:11 PM
02 RG- Thunderheaders 2:1, SE253 cams, SE 95ci w/ 10.25:1, SE A/C, PC-III, Blueprinte adrenilinecrash Dyno Results 5 04-14-2013 06:21 AM
Dyno sheet 110 SE 260 cams Yellow09SERG Engine Related 27 02-10-2012 06:51 AM
