Question? - Road Glide Forums
post #1 of 6 (permalink) Old 08-18-2011, 08:26 PM Thread Starter
Berndog's Avatar
Question?
I have an 11 road glide custom 103. While out to Sturgis I added head pipe, breather, and tts mastertune program from Kuryakyn. I already had Rush Big Louie 2.25's and wanted to keep those slip ons. Anyway it sounds good and the program is close. No popping on decel etc. But when riding, holding a constant rpm every now and then it feels like the bike loads up a little bit so i have to blip the throttle every now and again to clean it out. I assume its a little rich, and needs an adjustment. I'm gonna have to order the cables for my matertune and have it dynoed. My question is this. both places that are reasonably close to dyno the bike, arent familiar with the tts. They use the dyno jet powercommander V. Is there alot of difference for the dyno guys, or are they relatively similar to adjust?
2011 sedona orange, Heritage bars, V-Stream windshield, matching grips/pegs, backrests, and luggage racks. TTS Mastertune, HD Heavy Breather, Kuryakyn True Duals, and Rush Big Louie slip-ons.
Berndog is offline
post #2 of 6 (permalink) Old 08-19-2011, 06:26 AM
Gonekat's Avatar
Man i wish i could answer that. I see there has been quite a few people reading tand not one answer yet. Maybe shoot Frank over at Dragos Bike Works a PM. Guy knows A LOT!!
Gonekat is offline
post #3 of 6 (permalink) Old 08-19-2011, 07:23 AM
Moderator
BLKNCr6's Avatar
Berndog... Try Jamie over at Faribault Harley in Minnesota. He's good, and sorta economical, and I think will work with your tuner...
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
post #4 of 6 (permalink) Old 08-19-2011, 07:56 AM
Moderator
BLKNCr6's Avatar
Jason Kellis.... Sorry, not Jamie... He's good...
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
BLKNCr6 is offline
post #5 of 6 (permalink) Old 08-20-2011, 08:13 AM
Corrupted's Avatar
It could be all you need is a different map.
You can do your own tuning with the TTS but you will need the cables, a lot of good information here http://www.mastertune.net/ Steve Cole is the person you could talk to about the correct map.
Another place for help is on Harley Tech Talk.
You only need to be 10% smarter than the thing your working on!
Corrupted is offline
post #6 of 6 (permalink) Old 08-20-2011, 09:07 AM
Anybody that can tune sert can tune tts. But you can vtune yourself.
jeff is offline
Speaker Question (not a fitment question) FLTRXS18 Audio 9 12-31-2014 01:58 PM
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
