Cracked Fuel Filter Hsg - Road Glide Forums
post #1 of 6 (permalink) Old 08-20-2011, 05:22 AM Thread Starter
Phil_FLTRX's Avatar
Just a heads up for everyone with the newer glides.
Dropped my 2011 RGC off for 5000 mile service and a complaint about power and throttle response.
That was 3 weeks ago yesterday!!!
Turns out the fuel pressure was low because there is a crack in the fuel filter housing.
The kicker is that there are no parts available to fix it. Everything is backordered and I've been without a bike for 3 weeks.
I don't know how much longer I can wait for it before I lose my mind!!
Phil
2011 Vivid Black FLTRX, 107" Rev Perf, Zippers Thundermax AT, Roland Sands Speed 7 AC, Iron Aces iPhone holder, 8" KW, V&H Duals & Black Widows, DDM HIDs, ARC 6.5's, S.E. ported heads, 30 tooth frt sprocket.
You never see a Harley parked outside of a Psychiatristís office, now do you.....
Phil_FLTRX is offline
post #2 of 6 (permalink) Old 08-20-2011, 06:15 AM
JacktheBagger's Avatar
here we go again ..
Thanks for the heads up
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 6 (permalink) Old 08-20-2011, 06:31 AM
Gonekat's Avatar
so are there no parts because its not a part the often breaks and they dont need many on the shelf,.....or is it because there are an a$$ load of them breaking and they cant keep up with production? i hope its the first one. Let me know when your back on the road Phil, we will head out to north western CT
Gonekat is offline
post #4 of 6 (permalink) Old 08-20-2011, 06:37 AM
mmcmsw's Avatar
good to know.
Trailers are for Boats!!
mmcmsw is offline
post #5 of 6 (permalink) Old 08-20-2011, 07:44 AM
Sincecrazy's Avatar
The 08's had a recall on this. You would think they would have it fixed by now. Also you need to look at the filter top cap. I found mine to be defective allowing the o-ring to bypass at high RPM's.
Check this thread:
https://www.roadglide.org/showthread.php?t=8707
Sincecrazy is offline
post #6 of 6 (permalink) Old 08-21-2011, 07:59 AM Thread Starter
Phil_FLTRX's Avatar
My Indy has a 2nd bike in his shop with the same issue. That being said I'm not sure if the problem is isolated.
We looked at the o-ring set-up and that looks to be okay. Seems to be holding up very well after 4100 miles.
Gonekat, when the wife and I get our girl back, the plan is 2 tanks worth out and 2 tanks back.
I do have a planned ride coming up to benefit a vocational school. It's Saturday sept 17. You're more than welcome to come along. PM me if interested and I'll give you the details.
K&N Filter vs.HD Oil Filter RRHartzler Fluids and Lubricants 49 10-22-2016 07:00 PM
any good instructions to remove 2011 fuel tank to replace fuel filter? CPY84 Do-IT-Yourself 9 10-10-2016 11:31 PM
Fuel Filter service FLTR2008Trike *General Road Glide Discussions/Pictures 6 10-18-2014 10:34 PM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 11:38 AM
k & n filter to replace SE stage 1 filter raven006 ECM/Fuel Management systems 5 11-22-2010 04:24 PM
