Thunder Max? - Road Glide Forums
post #1 of 11 (permalink) Old 09-02-2011, 02:59 PM Thread Starter
Thunder Max?
Plan on a stage 1 this winter am still up in the air about what to do. Have read about these with the auto tune sounds good. Any opinions?
mrmoto95 is offline
post #2 of 11 (permalink) Old 09-03-2011, 11:21 AM
Autotune isn't 100% accurate. It will go in and make minor adjustments, but you still have to read the CLP's with the laptop, and then push them back into the module before they take effect. Then the process can be started again.
You'll need '09 headers, or you'll need to have bungs welded in, as the TM still uses the 18mm O2 sensors, and '10 and up uses 12mm sensors. You also lose the factory ETIMS with the TM, as the entire computer is replaced.
But, here's my story.
I installed TM with AT on my Dyna back in '08, along with pipes and a/c. Ran pretty good, but fuel mileage wasn't very good. In '09, I did a 107" with a fat cat. I could NEVER get the TM to work with that build. Even TM couldn't come up with a tune that would work. So, on the advice of a reputable mech, I installed the TTS. WOW!!! What a difference in power and fuel mileage! I never got better than 38 with the TM, the TTS is never less than 43, and on open highway, 48-50. Colorado was 58 mpg this summer! I also felt the TTS is easier to use.
I just picked up a Roadglide a couple weeks ago. It came with V&H dresser duals and cans, a/c, and the TM with AT. It seems TM may have made some improvements in the software and other things, as this one runs better than I expected. Mileage is still iffy, at about 40, and she still seems to run pretty warm on those hot days, but I think that is the nature of the bike.
When I found out the bike had the TM installed, it took me about 5 hours and a few calls with the dealership looking for the stock parts before I agreed to purchase. That's how unsure I am with the TM.
I'm very tempted to buy another set of headers and the TTS just to try. With my previous experience, the TM is better, but I still don't think it's all that and a bag of chips.
Long and the short? If I had been buying a tuner, it would have been the TTS, hands down, never even thinking twice or looking for something else. But, since the bike came with the TM, I'll give it a try again, but if it throws fits, it's gone!
Good luck in your decision!
Mike
2013 RGU
speedjunkie is offline
post #3 of 11 (permalink) Old 09-04-2011, 09:46 AM
DarbinCo's Avatar
I have the tmax in my 07 RG and I have no issues what so ever. From day one it made a huge difference in engine temps and the way the bike ran. Understanding I just need a bike that ran good and had decent power when touring 2 up. I didnt need a hot rod, it provided me with enough change in HP and torque I didn't then and still dont feel the need to spend money on cams etc.. Gas miliage varies from 42 to 50 depending on speed and if there's a passenger with me. I wouldn't change a thing if I did it again.
DarbinCo is offline
post #4 of 11 (permalink) Old 09-05-2011, 08:27 PM
Glider, what map are you running?
Mike
2013 RGU
post #5 of 11 (permalink) Old 09-08-2011, 12:01 AM
RobRG07's Avatar
Talking Thunder Max al the way
07 RG, 3 dealers tried to fix y tuning issues they installed and replaced parts, SE Racer tuner, etc. still ran like ^%$#!!. Installed TM in 35 min and bike never ran so well. Gets better every time i ride it. I would never use any other product except ThunderMax.
RobRG07 is offline
post #6 of 11 (permalink) Old 09-08-2011, 08:36 AM
I agree except I do like power. And over the winter was going to take my heads off shave them and put thinner head gaskets on. But after installing the PCV "autotune" the bike which ran great before just runs that much better. I will probably leave the top end alone now. I did install andrews 54s earlier in the year. A good tune is unbelievable. I have had alot of dyno tunes over the yrs bikes ran good. Even ran this bike on a dyno. Butttt with this PC autotune it now runs great even starts easier. And mpg has went up so for from 38 give are take to 43-44 mpg just going to work. I am still working with the trims and it keeps getting better. I come home from work get out the lab top and load the trims. They are about done trimming at that point I am going to switch the autotune off and call the map done.
JTultra is offline
post #7 of 11 (permalink) Old 09-08-2011, 08:40 AM
I have a complete 2009 stock exhaust system if anyone needs one.....
twowheel99 is offline
post #8 of 11 (permalink) Old 09-09-2011, 03:07 PM
roadgliderick's Avatar
Send a message via Yahoo to roadgliderick
i have TM on my 2011 roadglide with 555s woods cams and ness stage 1 i wouldnt change anything it runs perfect no heat issues either.
2011 roadglide firemist orange carlini 17 inch eval bars, C&C solo seat, paugho true duals with thunder header slip ons , oil bud oil cooler, cool sac grips, alpine cda 105 head unit, alpine type r speakers with alpine 2150 digital amp,stratum timer cover derby cover and a/c cover sinister wheels 21 up front 18 rear woods 555 cams with adjustable push rods and tmax tuner. bad dad front wrap and bad dad rear summit fender with hide-a-plate and flush mount rear LEDs arlen ness big bags.
roadgliderick is offline
post #9 of 11 (permalink) Old 09-10-2011, 03:00 PM
PFWiz's Avatar
Just got my stage 1 with Thundermax TBW. Because of stinky weather I only have about 30 miles on her...
Nice and smooth at speed. Bike pulls noticeably harder 70 - 90 mph in sixth.
Idle hunting a little bit, that should go away as TM auto tunes.
My right leg thermometer says the bike is noticeably cooler now!
I will write a real review after I get some miles on her...
PFWiz is offline
post #10 of 11 (permalink) Old 09-12-2011, 12:46 PM
DarbinCo's Avatar
Mike
Sorry I didn't see this.
I just set it up running the stock engine with my 2/1 pipe and air cleaner. Been long enough I really don't remember much but it was as close to stock as I. Could set it with thus extras I had.
2003 Anniversary Edition RG
2014 BMW K1600 GTL
DarbinCo is offline
Thunder max problem!!! Help!! Fxdf MenOfFriedland ECM/Fuel Management systems 2 07-19-2013 03:51 AM
Thank you Thunder Max dbell66253 ECM/Fuel Management systems 3 04-25-2012 10:58 PM
